Honda Rancher 350es Shifting Problems - Honda ATV Forum
post #1 of 8 (permalink) Old 03-07-2013, 11:25 AM Thread Starter
Rustakano's Avatar
Hey there. I have a 2004 Honda Rancher 350es with some shifting problems. Sometimes it shifts up, sometimes it doesnt. And usually when I shift up, I cant shift down from 1 to Neutral so I have to kill the engine on my quad, shift down into neutral and then start it back up. Should I check the wiring? New clutch? I just got a new angle sensor so I dont think its the problem. Thanks
Rustakano is offline
post #2 of 8 (permalink) Old 03-07-2013, 05:53 PM
Liked: 1734 times
don't know the elec shifts all that well ?..other than they are too much of a pain to own !!..lol. but...try this..see what ya get ?..try removing the shift motor..and front cover..so you can get into the gear box area...clean out all that oem grease..really good !!..put some fresh grease in..the kind thats not so dang thick !!..put it all back together...and see how well it shifts ??..this has helped some members here..can't say this will fix yours ?..but it's worth a shot !.
shadetree is online now
post #3 of 8 (permalink) Old 03-07-2013, 07:33 PM Thread Starter
Rustakano's Avatar
Sounds like that could be a good reason for the problem. Thanks! I'll try it out and let you know what happens!
post #4 of 8 (permalink) Old 03-07-2013, 09:49 PM
Liked: 1734 times
your welcome...i hope it works out for you !.
post #5 of 8 (permalink) Old 03-08-2013, 02:00 PM Thread Starter
Rustakano's Avatar
I can access the gearbox without taking off the motor correct? and should I expect alot of oil to be in there?
post #6 of 8 (permalink) Old 03-08-2013, 02:48 PM
Liked: 1734 times
i think you have to remove the shift motor in order to get the gear box cover off ?..no..there is no oil under the cover.
post #7 of 8 (permalink) Old 03-08-2013, 06:24 PM
RobK's Avatar
You may need to dissasemble the electric shift motor and clean and lube it. Also, I notice that mine has a hard time shifting into and out of R and 1 if the idle is too high.
RobK is offline
post #8 of 8 (permalink) Old 03-10-2013, 11:12 AM Thread Starter
Rustakano's Avatar
honestly, I think the problem is with the shift motor. Im gonna try to do something with that first and see if it works better. My speedometer is water damaged, kinda broken, rusted, missing capacitors, etc. I heard that that could affect shifting because of a messed up computer so maybe that could be the problem. Im almost positive that the problem is electrical
