02 400ex timing chain 1/2 tooth off!? - Honda ATV Forum
post #1 of 21 (permalink) Old 02-25-2013, 10:02 PM Thread Starter
WillNemeth90's Avatar
I just bought a brand new OEM 400ex timing chain and a stage 1 hot cam. I removed the decompression pin and spring. I put the crank mark right align with the hash mark right before the T. I install the sprocket as directed by the service manual, I do everything perfect but when I rotate it another 720 degrees back to the l T mark the lines in the camshaft gear are off 1/2 tooth. I tried advancing it a tad so when the tensioner kicks in it will pull it perfectly aligned. I was screwing with it for hours I can't get it right. What am I doing wrong!?!?
WillNemeth90 is offline
post #2 of 21 (permalink) Old 02-26-2013, 07:33 AM
Tippmann98's Avatar
You said you advanced it some so when the tensioner kicks in it will be perfectly aligned? As soon as you set the timing, you must install the tensioner and put tension on it. If you are rotating it without the tensioner in, it will definitely have some slack and appear off. Appear is the keyword. If the tensioner is not in and it's only half a tooth, you likely have everything lined up correctly. But install the tensioner and double check.
Tippmann98 is offline
post #3 of 21 (permalink) Old 02-26-2013, 07:35 AM
atvrider13's Avatar
Liked: 32 times
After the tensioner puts pressure on it , it will rotate back a little
atvrider13 is offline
post #4 of 21 (permalink) Old 02-26-2013, 10:23 AM
Liked: 316 times
1/2 tooth won't hurt anything
TRX2fiveO is offline
post #5 of 21 (permalink) Old 02-26-2013, 10:32 AM
Liked: 1734 times
i'm no expert by any means when it comes to sport bikes !!..buttt..i would like to ask..and throw this out to you..you said you put an after market cam in right ?..buttt..you installed an oem cam chain ?..soooo..my question is..is the after market cam sprocket bigger..smaller ? than the oem cam sprocket ??..this maybe why you can't get the timming marks to line up ?. just a thought here...lol.
shadetree is online now
post #6 of 21 (permalink) Old 02-26-2013, 10:35 AM
Tippmann98's Avatar
Hey Shade - I'm pretty sure the sprocket will be the exact same. It's the lobes that are different on aftermarket cams.
post #7 of 21 (permalink) Old 02-26-2013, 10:43 AM
Liked: 1734 times
i would like to know for sure ?, i'm learning here mind you !..lol. something about this after market cam is throwing the cam chain off ?..orrrrrrrr..the tensioner is not working right ?. if he has a new oem chain ?..and the hash marks are not lining up like they should ??.there is a reason for it !..lol. maybe he's not setting the crank right ??..i don't know ??..what i do know is..with a new cam chain..a new after market cam...it all should line up right !..wrong head gasket ?..base gasket ?..something is not right !.
post #8 of 21 (permalink) Old 02-26-2013, 10:58 AM
Tippmann98's Avatar
If you read his post it sounds like he is checking it all without installing the tensioner which will no doubt make the timing "appear" off a half tooth.
I've got a set of WebCams in my dirtbike. The lobes are shaped differently to create more lift and changes the duration but there is absolutely no difference in the sprocket size. A different sized sprocket would throw the timing off. You could set it right but after rotating the engine over back to the compression stroke it wouldn't line up at all with the TDC mark.
post #9 of 21 (permalink) Old 02-26-2013, 11:06 AM
Liked: 1734 times
i read his post...and your prob right ?..as he really does not get into detail if and when the tensioner is in ?..or bolted up ?..or what ?..lol. sooo..i really can't say. other than..they all should line up !..if not ?..then something is wrong somewhere !..lol.
post #10 of 21 (permalink) Old 02-26-2013, 01:32 PM
Josh's Avatar
aftermarket cams use the stock cam sprocket just have different shaft with taller and fatter lobes.
Josh is offline
