Honda rancher carb/choke - Honda ATV Forum
Old 02-07-2013, 01:08 PM   #1 (permalink)
91xjgawes's Avatar
Member #28506
View 91xjgawes's Photo Gallery(0)
2002 rancher 350.
First of all the rancher is hard to crank when cold. I have to give it gas and pull the choke and push it back in really quick.
Correct me if I'm wrong but shouldn't I be able to pull the choke out and it should just rev higher and continue to run? It will only run for about 1 second if you pull the choke out? What could this be?
I have cleaned the carb to no avail. I am thinking of just ordering a new one. Still has a little miss at idle and will sometimes shut off. I know it seems like I missed cleaning something, but I can tell you I have followed the write up on here and I am 99% it's all clean, maybe this could have something to do with the choke not acting right.
I have searched but can not seem to find any answers. Thanks guys.
91xjgawes is offline   Reply With Quote
Old 02-07-2013, 04:00 PM   #2 (permalink)
Xecuter242's Avatar
Member #27189
View Xecuter242's Photo Gallery(0)
Welcome to the forums! And I recently fixed this problem on my rancher, it's done that same thing for most of it's life.. What you need to do is tighten the choke cable, there's a rubber boot over the choke cable that you need to peel down, there's a tentioner under the boot that you need to tighten. Hope this helps you!
05 450R
07 KX250f -SOLD-
03 YZ250 -SOLD-
06 400EX -SOLD-
06 Recon
06 Rancher 350 -
Xecuter242 is offline   Reply With Quote
Old 02-07-2013, 06:38 PM   #3 (permalink)
91xjgawes's Avatar
Member #28506
Thanks for the help! Maybe I worded it wrong.
For instance in the morning when it's stone cold I can get it to run by giving it gas and playing with the choke, but if I pull the choke all the way out it will not run at all, almost like its got way to much fuel or something. Instead of the choke enrichining (sp) it it just chokes it down, like it floods it or something, wish I could describe it better. Basically the choke is not functioning properly and I don't know why! Lol
Old 02-07-2013, 06:45 PM   #4 (permalink)
rlfoulch's Avatar
Member #22125
View rlfoulch's Photo Gallery(0)
Check your oringvon the choke plunger
2013 Rubicon 28-10-12" mud witches on hd3 wheels
gone but never forgotten E.T. (90 fourtrax300fw)
94 sportster with andrews n4 cams hc pistons p&p heads drag pipes under drive pulleys
2010 Colorado 4 door 2wd
2013 recon es 23-8.50-12 front and 23-10.5-12deestone suretrack on hd3 wheels (her bike)
rlfoulch is offline   Reply With Quote
Old 02-07-2013, 06:56 PM   #5 (permalink)
Xecuter242's Avatar
Member #27189
Well, it still sounds a lot like the problem I was having. Did you try adjusting the choke?
05 450R
07 KX250f -SOLD-
03 YZ250 -SOLD-
06 400EX -SOLD-
06 Recon
06 Rancher 350 -
Old 02-07-2013, 07:52 PM   #6 (permalink)
91xjgawes's Avatar
Member #28506
Didn't know you could adjust the choke?
Old 02-07-2013, 08:03 PM   #7 (permalink)
Xecuter242's Avatar
Member #27189
Remove the rubber boot and spring (in the picture)Honda rancher carb/choke-imageuploadedbytapatalk1360288939.758402.jpg
And take the plastic nut and tighten it.
Honda rancher carb/choke-imageuploadedbytapatalk1360288988.610581.jpg
05 450R
07 KX250f -SOLD-
03 YZ250 -SOLD-
06 400EX -SOLD-
06 Recon
06 Rancher 350 -
Old 02-07-2013, 08:03 PM   #8 (permalink)
Liked: 52 times
Welcome to da forums... When you go to start it first thing,turn key to on,run switch to on,pull the choke all the way out,and hit the starter button,don't pump,or play with the throttle any,once it fires off,lower the choke button until it is idling a little high,but not way up high as it will flood the plug,and cause the engine to start bogging down,and eventually will fuel foul the spark plug...Install a new correct spark plug,and try it this way,and see if it doesn't work better for you...The "choke" is not a normal cut back on the air supply choke,but is actually an enrichener valve which adds more gas to the idle circuit which along with the timing not advancing at lower rpms will cause it to load up rather quickly,and start to fuel foul the spark plug if it isn't cut back down,or turned off soon...It should only be ran for a few seconds to a minute,or two at most,not 5-10 minutes...
Old 02-07-2013, 08:29 PM   #9 (permalink)
91xjgawes's Avatar
Member #28506
Thanks for everyone's help it is greatly appreciated!
When I go to start it I turn key on pull choke all the way out, it stays there. I push starter button only and it only turns over and over.
Push choke back in and push starter button and it turns over a few times and finally starts but will shut off if you don't give it a little gas.
That's what I'm trying to say, the choke only aids in starting if while pushing the start button I pull up really quick and push back down immediately it will crank. But with choke fully pulled it will not continue to run, not even for a few seconds.
Old 02-07-2013, 08:38 PM   #10 (permalink)
91xjgawes's Avatar
Member #28506
Remove the rubber boot and spring (in the picture)Attachment 11941
Attachment 11942
Thanks buddy, nut was a little loose it stays up good now! Still won't run with it up though
2002 honda rancher 350 choke cable replacement
2002 honda rancher choke starter plug
2004 honda rancher 400 will not run unless choke
choke on honda trx 350
honda 350 rancher choke adjustment
honda rancher choke
honda rancher only runs on choke
how does yhe choke work on a 02 honda rancher
how to choke honda rancher
rancher choke nut
replace 2005 rubicon choke cable
why does a 02 honda rancher shut off with choke off
