How do I clean a rusty metal gas tank - Honda ATV Forum
Old 12-23-2012, 08:35 PM   #1 (permalink)
BND
BND's Avatar
Member #27113
View BND's Photo Gallery(0)
How would I go about cleaning my Metal gas tank? The inside is all rusty and I wanna clean it so no rust will get into my brand new carb.
BND is offline   Reply With Quote
Old 12-23-2012, 10:05 PM   #2 (permalink)
Kevron's Avatar
Member #13358
View Kevron's Photo Gallery(0)
Liked: 14 times
Drain and remove the tank. Get some BBs, drop in tank and shake. Remove BBs, rinse out with fuel, repeat. This is how I've done it I'm sure others will give some good suggestions also. They make coatings that you put in the tank after its cleaned that you might want to check out. Good luck.
Kevron is offline   Reply With Quote
Old 12-24-2012, 04:00 AM   #3 (permalink)
CDs.CycleShop's Avatar
Member #14680
View CDs.CycleShop's Photo Gallery(0)
Liked: 46 times
Try about a cup or so of course sand and shake like you got a hold of the devil. poor out, and repeat until there are no more rust chunks in the sand that your pouring out. if you decide to use the BB's instead be careful not to shake the tank to hard, as you could shot ping the tank, that would look like a 1000 little pumps on the tank, the sand is more forgiving. use water to flush the sand out and then dry with compressed air. I would recommend buying a gas tank sealant kit. the auto parts store usually has the tank repair kits. Good Luck!!!!!!!!!
02TRX416ex//Wiseco 11:1 piston//Magnum stage 2 cam/Wiseco Timing Chain/Kibble White valves/AMR Stage 3 CDI & Coil/Custom Built Vance&Hines exhaust/Hinson clutch basket-plates/Moose Air filter/Armadillo Full chasis skid plate/Tusk nerfbars/Custom Built Rear shock/GT Thunder Rear susp.link/SRP Dual row rear bearing carrier/Boss Wheel and axle Bearings/ProArmor front bumper/MSR chrome Bars/OURY Grips/MotionPro cables/
97 Polaris 300 4X4//Wiseco piston/fmf full exhaust(SOLD)
08 Kymco MXU 150
07 Suzuki Eiger 400 4X4
02 Yamaha PW 80(SOLD)
87 TRX125 FOURTRAX
A learning experience is one of those things that says, "You know that thing you just did? Don't do that."
CDs.CycleShop is offline   Reply With Quote
Old 12-24-2012, 07:11 AM   #4 (permalink)
bmoore's Avatar
Member #26279
View bmoore's Photo Gallery(0)
Ive done this two ways one kerosene and gravel shake till rust stops or small non rusty chain ans shake till rust stops shake repeatedly, I woluld not recomend sand unless you plan on removing pet cock eiter way when done rinse several times kerosene let air dry. back when i used to do this did not know of seal kits usually worked with out, they do make sealer kits now and most gas tank or radiator shops will reseal for ya not to expensive.
bmoore is offline   Reply With Quote
Old 12-24-2012, 08:07 AM   #5 (permalink)
HondaGav's Avatar
Member #19371
View HondaGav's Photo Gallery(0)
Liked: 56 times
I throw in some nuts and bolts along with some diesel fuel and shake it for awhile. Then just drain it and it's clean.
-2007 King Quad 450 (Work Horse)
-1984 Honda TRX200 (Donor)
-1989 Skidoo Mach 1 (Play Toy/Winter Headache)
-1966 Series IIA Land Rover (Major Project)
HondaGav is offline   Reply With Quote
Old 12-24-2012, 08:25 PM   #6 (permalink)
jkhuntin's Avatar
Member #4493
Liked: 16 times
Welcome from the Volunteer state. All above are good suggestions. Kerosene and sheet metal screws works well also. Kream makes a great tank sealant. Just make sure that you get all heavy rust out of the tank.
2004 Rincon
2" lift
27" mudlites, ITP SS212's
Mud bike
2013 Rancher 420 AT.
Old 01-01-2013, 05:07 PM   #7 (permalink)
mrxlh's Avatar
Member #27544
View mrxlh's Photo Gallery(0)
Once you get the loose crap knocked out, treat it with Ospho. It will chemically turn the rust into iron, then you can seal it with barbee tank liner called Tank Saver. Here is the link to their catalog.The Barbee Company
Here is the link for ospho. http://www.ospho.com
Ryan
2010 Honda 420 Rancher ES, Mine
2013 Honda 420 Rancher AT EPS, Hers
mrxlh is offline   Reply With Quote
Old 01-01-2013, 05:11 PM   #8 (permalink)
mrxlh's Avatar
Member #27544
I have used Kreem in the past and don't like it as well as Barbee. As if it does start to rust again, and then peel, you are stuck with the Kreem peeling and cracking. Barbee can be removed chemically.
Ryan
Old 01-01-2013, 05:37 PM   #9 (permalink)
kilabeez0's Avatar
Member #27500
View kilabeez0's Photo Gallery(0)
fill with muriatic acid. don't inhale the fumes its nasty. after about 15-20 minutes pour it out into a sealed container for disposal. rinse thoroughly with WATER. now fill it with about 1/4 water and pour in some baking soda to neutralize the acid. shake it around real good. rinse it out with water a few more times. now fill it with acetone to absorb all the moisture in the tank. it will immediately flash rust if you dont fill it with gas or some kind of coating. I prefer red kote over kreem. kreem is garbage. red kote is awesome stuff. I've used numerous methods to fix many metal tanks as i repair and restore a lot of 3 wheelers and muriatic acid is hands down the best and easiest way. google it.
kilabeez0 is offline   Reply With Quote
Old 01-02-2013, 08:07 AM   #10 (permalink)
Greg1994's Avatar
Member #21985
View Greg1994's Photo Gallery(0)
I did it this way and it worked great. Had some trouble getting ALL the BB's out afterwards, so plan on a bunch of shaking. I was concerned about the surface rust originally but afterwards it looks brand new inside.
Greg
League City, Texas
1994 Fourtrax 300 4X4
2006 Yamaha Grizzly 660 Special Edition
1991 Yamaha Big Bear 350
Greg1994 is offline   Reply With Quote
1984honda gas tank 4x4
best way to clean atv gas tank
fuel tank 1984 honda atv 200s
how do i get rust out of my gas tank on my fourwheeler
how to clean a atv gas tank
how to clean fourtrax 300 tank
how to clean metal atv gas tank
how to clean out rusty fuel tank quad
how to clean rust out of atv gas tank
how to fix rusty meatel atv fuel tank
how to remove bbs from gas tank
metal honda four trax gas tank
