frequent high idle and stalls 1986 trx 350 - Honda ATV Forum
Old 12-03-2012, 03:14 PM   #1 (permalink)
jdub336's Avatar
Member #26686
View jdub336's Photo Gallery(0)
hi all, i just rebuilt my 350 from the jug up. new rings fresh hone, rebuilt head, new gaskets and a carb rebuild also. having an issue with running, sometimes it runs great and others it will cut out and stall. when it does this i check spark which is fine. fuel seems to be getting there also. when it dies i try to restart it and it doesnt want to go. if i let it sit a while it will restart and run fine. then i will ride for a bit and after a while when i stop if i leave it in gear it will slow down til it stalls. if i catch it before it stalls hit neutral and feed it some throttle it will rev up and hold high idle. i try to kick it down by feathering but it will stay high idle. the only way it will kick down is to drop it in to gear which after it learches forward it calms right down. after i do that i can stick it back in neutral and it will idle fine, no problems. it only acts up if it stalls, or if i catch it before it does.
any ideas? thanks in advance -Johnny
jdub336 is offline   Reply With Quote
Old 12-04-2012, 01:30 AM   #2 (permalink)
Liked: 52 times
If you didn't remove,and clean the fuel tank,fuel pump,petcock,replace the fuel lines,or install an inline fuel filter then I would say that you have trash in the carb...
Old 12-04-2012, 05:11 PM   #3 (permalink)
jdub336's Avatar
Member #26686
thanks i will give that a try. i did a carb rebuild and there is an in line filter, it just seems like its either getting too much or not enough fuel. if i go full throttle from a dead stop it will die down, then come right back, if i get on it in stages "feathering" it will come right to life, but too much too fast and it sputters out. sprayed all around carb and no air leaks. i wonder if the bowl isn't filling up all the way? its not running out of the carb so i know its not overfilling. i don't know i can ride it and its ok, not great but ok. its a pain to start too. anybody else has any ideas it would be very helpful. youre probably right the carb is plugged or something. all that work for nothing.
Old 12-04-2012, 07:09 PM   #4 (permalink)
1991honda350's Avatar
Member #14306
View 1991honda350's Photo Gallery(0)
Liked: 4 times
here is a weird thing to check , my 350 does this , at the throttle , bend the throttle cable see if the rpms go up or down , I found this issue when I was putting my handlebar mitts on , as I was tightening them up the engine started to race , and I was like wth man... then I loosened them off and the rpms went back down I tested this mystery by moving the throttle cable and the rpms went up and down accordingly, now I know why the engine races, well at least one reason anyhow ... for me it means a new throttle cable is in the future
1991 Honda 350 (the beast)snorkeled, vampire tires on the back diff clutch mod, led headlights
1988 fourtrax 300-stock so far ( wifes ride)
1990 ford ranger -fishing truck
1977 ford f250- firewood truck, quad hauler
Yamaha moto4 225
check out my youtube page here... http://www.youtube.com/user/brett196...d?feature=mhee
1991honda350 is offline   Reply With Quote
Old 12-04-2012, 07:42 PM   #5 (permalink)
HondaGav's Avatar
Member #19371
View HondaGav's Photo Gallery(0)
Liked: 56 times
You're not getting enough fuel.
The carb bowl isn't filling up as fast as the engine is draining it, clean your carb and you should be good.
-2007 King Quad 450 (Work Horse)
-1984 Honda TRX200 (Donor)
-1989 Skidoo Mach 1 (Play Toy/Winter Headache)
-1966 Series IIA Land Rover (Major Project)
HondaGav is offline   Reply With Quote
Old 12-04-2012, 08:39 PM   #6 (permalink)
Tippmann98's Avatar
Member #15501
View Tippmann98's Photo Gallery(0)
Take your fuel line off and make sure gas is flowing freely. If it's just dribbling thru your petcock could need be clogged up.
Tippmann98 is offline   Reply With Quote
Old 12-04-2012, 08:44 PM   #7 (permalink)
jdub336's Avatar
Member #26686
thats what i am thinking too, the float is not adjustable though. you can only replace it. poor design lol. i don't think its the cable but you never know, it seems internal like it acts when its out of gas and it revs higher. i am going to pull carb tomorrow and i have some carb dip i will soak it in and blow air through all the orifaces and see if i find any dirt or gunk. who knows. thanks again. any more ideas feel free to add i am willing to try anything once lol thanks -Johnny
Old 12-04-2012, 09:04 PM   #8 (permalink)
Tippmann98's Avatar
Member #15501
One other thing to check is make sure your gas cap is venting correctly. I had a '85 ATC 250sx with a plugged vent and I'd hop on it and ride for 30 seconds or so and it'd shut off on me because it was vapor locking. Next time it stalls on you, unscrew the cap and see if it's pressurized.
Old 12-05-2012, 06:19 PM   #9 (permalink)
HondaGav's Avatar
Member #19371
Liked: 56 times
I had a 71 Skidoo Nordic did that, vent got ice built up in it (To many snowbanks) and pressurized the tank enough that it couldn't pump anymore.
Old 12-05-2012, 07:22 PM   #10 (permalink)
jdub336's Avatar
Member #26686
i checked the vent and it is open. i didn't get a chance to pull carb but before it rebuilt it it ran good, not great but good. i never had a problem before this. i only rebuilt carb for the fact i was doing everything else. wondering if i should put old internals back in carb and see what happens?
1984 honda trx200 stalls when i put it in gear
1986 honda trx 200cc atv idles really high
1986 trx 250 high idle after giving gas
85 honda atc 250sx starts but dies after riding
fourtrax 125 runs high then dies
my 1986 honda fourtrax 70 dies when throttled
my quad is ideling slow
my sukuzi 185 some times reves up high
trx 200 idles high in gear
vedio john deere js28 throttle real high how to fix
why does my atv idle high
why does my four wheeler run good but idles high then dies
