how to adjust valves on 1990 honds fourtrax 300 - Honda ATV Forum
Old 12-01-2012, 08:26 PM   #1 (permalink)
Prhodes's Avatar
Member #17432
View Prhodes's Photo Gallery(0)
I just rebuilt a Honda fourtrax 300 and it has no power and I know its the valves so.I was wondering the tolerences and how to get it top dead center. Thanks
Prhodes is offline   Reply With Quote
Old 12-01-2012, 10:50 PM   #2 (permalink)
antjaw's Avatar
Member #24336
View antjaw's Photo Gallery(0)
Does it have a pull start?
antjaw is offline   Reply With Quote
Old 12-01-2012, 10:59 PM   #3 (permalink)
Liked: 52 times
Remove the timing plug,use the kick starter to slowly turn the engine over to the t timing mark(remove the spark plug makes it so much easier),or go download the free e manual in the schematics,and repair manuals section in here for fast easy referral,and complete directions on how to do anything to your atv... hondaatvforums.net is the password...
Old 12-02-2012, 08:13 AM   #4 (permalink)
Prhodes's Avatar
Member #17432
I looked but I can't find one that hasn't been deleted. Can you post a link? Thanks
Old 12-02-2012, 09:48 AM   #5 (permalink)
Prhodes's Avatar
Member #17432
Okay so I put it TDC and the valves are tight so I loosened them a lot but still too tight and I can't get the feelergauge in there for nothing. Help please
Old 12-02-2012, 09:50 AM   #6 (permalink)
antjaw's Avatar
Member #24336
There is an intake and an exhaust stroke. Both are at TDC. One of the has the valves tight and the other one loose. Rool it to TDC again to change the stroke and see if they loosen up. You want to adjust them when they are on the loose stroke.
EDIT: This is from my manual. It may explain better.
Rotate the crankshaft using the recoil starter knob
to align the ‘‘T’’ mark on the flywheel with the index
mark on the rear crankcase cover.
Make sure the piston is at TDC (Top Dead Center)
on the compression stroke.
This position can be obtained by confirming that
there is slack in the rocker arm. If there is no slack,
rotate the crankshaft one full turn and match up the
‘‘T’’ mark again.
Old 12-02-2012, 07:05 PM   #7 (permalink)
Prhodes's Avatar
Member #17432
I figured out what it was. It was way out of time
Re timed it and now its running pretty good. Still think the valves are in need of adjusting. Looks like a project for next weekend
Old 12-02-2012, 07:52 PM   #8 (permalink)
Liked: 52 times
I'd adjust the valves to exact specs asap BEFORE I rode it,or ran it any more...
Old 12-02-2012, 09:53 PM   #9 (permalink)
Prhodes's Avatar
Member #17432
Trust me I am. I adjusted them before this to .006. But who knows it being out of time it may be way off. Oh and its got a 98 wiring harness and CDI on it. Is that gonna cause it any problems? Just a thought. Thanks
Old 12-02-2012, 10:22 PM   #10 (permalink)
Liked: 52 times
It shouldn't be an issue if the entire harness was used,and connected properly...You said that you tried to adjust the valves when the timing was not on tdc on the compression stroke which tells me that they need adjusting again,or you may mess a valve up,or cause a lean condition which can burn the cylinder,and piston up rather quickly...
1990 honda fourtrax 300 value adjustment
1990 honda fourtrax 300 valve adjustment
1990 honda fourtrax valve adjustment
91 300 honda valve adjustment
honda 1990 to 300 valve
honda 300 fourtrax valve adjustment
honda fourtax 200 valve adjustment
how to adjust the valves on a 300 fourtrax
how to adjust valves on a honda fourtrax 300
what cause for honda 300 trx 4 trax 1990to lose power
