06 TRX350FE Racnher Won't Start - Honda ATV Forum
Old 06-15-2009, 12:52 PM   #1 (permalink)
E30M3CRAIG's Avatar
Member #388
View E30M3CRAIG's Photo Gallery(0)
I have a 2006 FourTrax Rancher TRX350FE that will not start. My brother was using this on Sunday and while crossing a 6" deep creek it started to lose RPM's and stalled out. It would not restart. After towing it home I charged up the battery and still no start.
The battery has plenty of voltage and the starter turns with no problem. I put a spark pug tester on and it is not getting any spark. I tested the coil and there is basically no resistance on the coil. I'm only getting like 1 ohm if that. If I use the resistance nosie test, it is full volume. There is a blueish green wire and a black wire going to the coil. I tested both of them and there is no voltage going to either while ignition is on or while starting.
Where should I look next?
Thank You for any Help.
I was reading online that the CDI may be a problem. Where is this located exactly? Is it near the Control Unit and the Rectifier?
E30M3CRAIG is offline   Reply With Quote
Old 06-16-2009, 08:49 PM   #2 (permalink)
brucefulcher's Avatar
Member #358
View brucefulcher's Photo Gallery(0)
the brain boc aka CDI like you said is prob the problem, when that box aint working aint nothing going to work and i know that from experience
Bruce
04 Rancher AT/ES 4x4
brucefulcher is offline   Reply With Quote
Old 06-18-2009, 02:13 PM   #3 (permalink)
E30M3CRAIG's Avatar
Member #388
Well I bought a new CDI and installed today 6/18/09 and it still does not start or have any spark. Makes me wonder if it really might be the coil. How can you test the CDI box to make sure its putting out what its supposed to be putting out?
2000 honda trx350fe not getting spark
2004 honda trx350 rancher loses spark
2006 trx 350 coil issues
2006 trx350fe no spark
coil for 2006 honda fourtrax rancher 350
honda trx350fe fourtrax 350 4x4 es won't start
honda trx350fe no spark
how to test coil on 2004 honda rancher
no spark on 2003 honda trx350fe
trx 350 rancher no spark
trx 350fe 2000 wont crank
trx350fe no spark
