300 ex no spark - Honda ATV Forum
post #1 of 11 (permalink) Old 10-13-2012, 11:33 AM Thread Starter
thegeneral's Avatar
300 ex no spark
I'm not real sure of the year , but I'm told it's a 94. I have no spark, and when I jumper to the kill switch I still have nothing. But when I turn the switch off I get spark momentarily. Does anyone have any idea on what could be causing this? I'm starting to get really aggravated.. thanks
thegeneral is offline
post #2 of 11 (permalink) Old 10-13-2012, 12:48 PM
Liked: 316 times
LEts disconnect and bypass the reverse switch to eliminate that. . . look on the upper left side of the frame, locate the harness you will see a big rubber cylindrical cover slide it back and locate the gray wire and the gray/black. unplug the from the connectors, now make a short jumper wire and connect the 2 wires together (the ones in the harness the gray and gray/black) see if you can start then. .
Also make sure your reverse lever on the engine is down
oh yeah welcome to the forums.
TRX2fiveO is offline
post #3 of 11 (permalink) Old 10-13-2012, 01:15 PM Thread Starter
thegeneral's Avatar
I've already done all that.... The only time i get spark is when i turn the Killswitch off! But only momentarily... That is why I'm at a loss for ideas
post #4 of 11 (permalink) Old 10-13-2012, 01:16 PM Thread Starter
thegeneral's Avatar
Is there supposed to be 12 volts going to the cdi box? Or is the switch act as a resister?
post #5 of 11 (permalink) Old 10-13-2012, 01:33 PM
Liked: 316 times
has the key switch been bypassed?
post #6 of 11 (permalink) Old 10-13-2012, 02:44 PM Thread Starter
thegeneral's Avatar
Yes and no.... I have tried both to get spark and the same thing happens
post #7 of 11 (permalink) Old 10-13-2012, 05:39 PM
Liked: 316 times
in order to test the components of this system you will need a peak voltage adapter and a muti meter. The CDI cannot be tested but for the giggles I would unscrew the pulg boot and cut about 1/2" off and screw it back on. remove the chassis ground and clean it and the frame, also check the fuses by the battery for corrision.
post #8 of 11 (permalink) Old 10-14-2012, 10:04 AM Thread Starter
thegeneral's Avatar
I did shorten the spark plug wire, but i did not clean the ground..... Fingers crossed
post #9 of 11 (permalink) Old 10-14-2012, 03:21 PM Thread Starter
thegeneral's Avatar
Fuses are good, grounds are good, still the same.... I only get spark when i turn the kill switch off
post #10 of 11 (permalink) Old 10-16-2012, 05:00 PM Thread Starter
thegeneral's Avatar
I put a resister in line with the ignition and have spark, but it well not rev all the way up........
