Project quad rebuild - Honda ATV Forum
Old 10-11-2012, 11:35 PM   #1 (permalink)
stomper's Avatar
Member #15673
View stomper's Photo Gallery(0)
I just purchased a 2001 fourtrax 350 ES. The quad is in realy nice shape, but, there is always a but, the engine/trany came as a box of parts. I got it cheap enough knowing that if I had to purchase a good used engine I would still be getting a good deal. The previous owner said the tranny wasn't shifting so he took the engine/trany apart to check it out and found out that it was one of the gears on the electric shifter. He had no idea how to put it back together and it has been sitting in his garage for the past year and decided to sell it. I downloaded the service manual and have taken an inventory of the parts and there are a few small peices that are missing but nothing serious. The case is split and the cranck, piston and cam shaft are still installed. All the bearings are still good. I cleaned the half of the case that doesn't have the crank ect in it and have lubricated the bearings. Everything seems fine with it. I need to clean the half that still has the the crank and other parts in and I don't want to remove the parts. What is the best way to clean it and with what. It only need to be flushed to clean out the dust that has settled from sitting for the past year. on the other half I used varosol first and then sprayed it down with walters slap shot, an arosol cleaner/degreaser. It cleans every bit of oil and grease off of anything. I didn't know if I should use it or not on this half because I can't get at the crank bearing to relubricate it. Is there something else that would work better and still leave a bit of lubrication for the bearings.
stomper is offline   Reply With Quote
Old 10-11-2012, 11:44 PM   #2 (permalink)
rich450es's Avatar
Member #14117
View rich450es's Photo Gallery(0)
i use starting fluid to clean the parts before final assembly . then oil as i go , and i dont skimp on the oil
2000 FOREMAN 450 ES-S
warn 424 sold
14% 300 basket gear reduction
2500 lb warn winch sold
29.5x10x12 swamplites on ITP C-5 wheelssold
ssatv 2in lift
superatv disk brake conversion kit sold
progresive 512 shocks
the original custom 4inch PVC storage on front rack
if you need 450 parts PM me
rich450es is offline   Reply With Quote
Old 10-12-2012, 01:01 AM   #3 (permalink)
Liked: 54 times
You'll be fine using what you used on the other half,just pour some good clean engine oil into the crankshaft journal areas,and into the end bearings....
Old 10-12-2012, 01:02 AM   #4 (permalink)
Liked: 54 times
ps...
Old 10-12-2012, 05:13 AM   #5 (permalink)
Dan G's Avatar
Member #11269
View Dan G's Photo Gallery(0)
Liked: 6 times
Mmm, a basket case! Just picked up one of those myself a little while ago... I use the big blaster can of wd-40 to flush out the bottom end and bearings when I do mine, then lube them up good with a hand oiler full of good motor oil. On the overhead cams I use some assembly lube on the cam journals and lobes to keep it lubed on the first start. Always pop the valve cover and add a few cap fuls of oil, then pop an oil line lose and turn the engine over with a drill until its primed before you do the first start up, and you should be good to go.
Old 10-12-2012, 09:40 AM   #6 (permalink)
stomper's Avatar
Member #15673
Thanks guys. Pictures to come. I wish I would have taken a picture of the engine in the box. I was having my doubts once I got it home but it doesn't look that bad now that I have everything organized.
Old 10-12-2012, 11:02 AM   #7 (permalink)
2000300ex's Avatar
Member #13195
View 2000300ex's Photo Gallery(0)
just hope he included all the parts lol
Sold
300ex
128 main jet
white bros e seires exhuast
k&n air filter
mair plastics
dg alloy red nerfbars
renthal h-bar
moose aluminum handguards with homemade roost deflectors
racks front and back
2.5"fender flares
1984 Toyota Pickup 4x4
2005 Dodge Dakota CrewCab 4x4
2000300ex is offline   Reply With Quote
Old 10-12-2012, 12:11 PM   #8 (permalink)
SteepleChase's Avatar
Member #13572
View SteepleChase's Photo Gallery(0)
ya x2 for me, hope all the parts are there for ya...that'll be a real pain if you're missing anything small
SteepleChase is offline   Reply With Quote
Old 10-12-2012, 12:26 PM   #9 (permalink)
Kennerdell's Avatar
Member #24388
View Kennerdell's Photo Gallery(0)
X2,gonna need to see some pics
1990 RED FOURTRAX 300
24" TRAIL WOLFS CARLISLE (front)
25" MUD LITE ITP (back)
2002 Polaris Magnum 325 4x4
26" GBC Gators (Front)
26" Kenda Executioners (Back)
Kennerdell is offline   Reply With Quote
Old 10-12-2012, 01:08 PM   #10 (permalink)
Benji's Avatar
Member #24373
View Benji's Photo Gallery(0)
Sounds fun, i need to find me a project bike!
2011 Foreman 500 4x4
Power Steering
2" lift
Norkled'
HID's
27" Zilla's
Highlifter Outlaw Clutch Kit
Benji is offline   Reply With Quote
atv rebuild project
best way to clean atv parts for rebuild project
father son quad project
honda atv 200
honda atv overhead cam shaft bearings
honda atv project
looking for a used quad to rebuild
project for 500 honda atv engine
project quad
quad rebuild project
rebuilding atv for senior project
repairing atv project
