reset idle speed - Honda ATV Forum
Old 08-23-2012, 10:52 PM   #1 (permalink)
ddot06's Avatar
Member #22377
View ddot06's Photo Gallery(0)
Question reset idle speed
I accidentally inscrewed the idle speed control on my 02 fourtrax, not knowing thats what it was. now I need to reset it to the right adjustment. How do I reset the screw to the right position?
ddot06 is offline   Reply With Quote
Old 08-23-2012, 10:53 PM   #2 (permalink)
ddot06's Avatar
Member #22377
Unscrewed.*
Old 08-23-2012, 11:26 PM   #3 (permalink)
Welcome to the forums. I always just set the idle speed by ear. But the proper way, is to set it at 1,400 RPM by hooking a tachometer up to it.
Old 08-23-2012, 11:42 PM   #4 (permalink)
ddot06's Avatar
Member #22377
I don't have a tachometer. How many times should I turn the screw and where should I start with it all the way in or out?
Old 08-23-2012, 11:46 PM   #5 (permalink)
If you're adjusting the idle speed, there's no set number of turns. You just have to turn it until the idle speed sounds right. Just start it up and if it's not idling or idling too low, turn the idle speed screw clockwise to speed it up. If it's idling too fast, turn the idle speed screw counterclockwise to slow it down. Just go by the sound of the engine to get it close. If it's idling too high, it will jump or jerk when you shift into gear and if it's idling too low, it will probably stall out on you sometimes. Just keep adjusting it until you're satisfied with the idle speed. That's all you can do if you don't have a tachometer. And you need to have the engine at normal operating temperature when you set the idle speed. If it isn't, the idle speed may change after it warms up.
Old 08-23-2012, 11:48 PM   #6 (permalink)
And you are talking about the idle speed screw and not the pilot (air/fuel) screw, right?
Old 08-24-2012, 12:12 AM   #7 (permalink)
ddot06's Avatar
Member #22377
Ya the idle speed screw. Thanks! I was just worried when it fired up and ran wide open.
Old 08-24-2012, 12:13 AM   #8 (permalink)
If it's running wide open, just turn it down a little and then start it and adjust from there.
Old 09-17-2012, 01:06 PM   #9 (permalink)
foyota86's Avatar
Member #7937
View foyota86's Photo Gallery(0)
Isn't there a way to turn a DMM ( digital volt meter ) into a tach?
foyota86 is offline   Reply With Quote
Old 09-17-2012, 03:25 PM   #10 (permalink)
Liked: 52 times
Only if it has tachometer as one of its options Foyota...
adjust idle speed honda atv
adjusting idle speed honda 4 wheeler
atv jumps when put into gear
atv tachometer
atv tachometer for idle speed
four wheelers with speed adjusments
honda accord 2000 how to adjust idle speed
how to set idle on atv
how to turn idle speed screw wd40
readjusting idle speed on a 4wheeler
what is the idle speed of honda 350 atv
what would make a 4 wheeler idle too fast
