2002 recon will not go into reverse all the time - Honda ATV Forum
Old 08-18-2012, 05:04 PM   #1 (permalink)
kevinsonnier24's Avatar
Member #10870
View kevinsonnier24's Photo Gallery(0)
My Honda Recon 250 ES will not go into reverse all the time I push the red button down and pull the break back and sometimes it will and sometime it want I replaced the angle sensor for the forward gears but can't figure out this reverse the down push button works good for the forward gears is their something on the back of the motor where the cable goes ?
kevinsonnier24 is offline   Reply With Quote
Old 08-18-2012, 05:12 PM   #2 (permalink)
Liked: 52 times
Have you tried adjusting the reverse lockout cable yet?? Follow the cable to where it enters the engine,loosen the locking nut,screw the cable outwards a few turns,then lock the nut back down...Should alleviate your hard to get into reverse problem...
Old 08-18-2012, 05:57 PM   #3 (permalink)
Member #10870
I have not but I sure will try that thanks so much !
Old 08-18-2012, 06:03 PM   #4 (permalink)
Liked: 52 times
Let us know if that solved the problem...You're welcome...
Old 08-19-2012, 02:01 AM   #5 (permalink)
If adjusting the reverse cable doesn't help, check your reverse shift switch on the rear of the engine. It could be going bad or the wire might have a bad connection where it attaches to the shift switch.
2002 honda 250 recon reverse recall
2002 honda recon 250 es
2002 honda recon 250 es shift problems
2002 honda recon es putting in reverse
honda atv reverse switch
honda recon es wont go in reverse
honda recon es wont go into reverse
honda recon not shifting into reverse
honda recon reverse
honda recon reverse how to
honda recon reverse problem
honda recon wont go in reverse
