95 fourtrax rear axle removal - Honda ATV Forum
post #1 of 46 (permalink) Old 02-21-2010, 02:06 PM Thread Starter
brlrace's Avatar
can someone help me with how to remove the rear axle on my 95 300 four trax
brlrace is offline
post #2 of 46 (permalink) Old 02-21-2010, 02:18 PM
Don't forget to take the rear brakes and brake backing plate off after you take the two big axle nuts off the brake side.
post #3 of 46 (permalink) Old 02-21-2010, 02:23 PM
Liked: 1731 times
sure..i can try...lol..first off..remove the right side..brake cover..when you get to the brake drum..don't try to force it off..most honda's have a tiny o-ring around the axle right there..it's hard to see.not sure if you have one on yours..but check to see...remove it..then slide the brake drum off..remove the brake shoes..take all your brake cables off..lay them aside somewhere out of the way..unhook the air breather hose that leads to the brake backing plate..now..inside ..where your shoes were..should be 4 bolts in the center..take them out..after you get them out..the whole brake assembly should come off..now..if you don't have the left rear side off..wheel..hub..take it off..jam nuts and all..after you got all this..the axle should slide out from the rear right..hope this helps.
post #4 of 46 (permalink) Old 02-21-2010, 02:24 PM
Liked: 1731 times
dang helmut..if i knew you were that fast..i woulda stoped typping..lmfao
post #5 of 46 (permalink) Old 02-21-2010, 02:25 PM
Hear is how to remove the rear brakes and backing plate.
post #6 of 46 (permalink) Old 02-21-2010, 08:21 PM Thread Starter
brlrace's Avatar
thanks guys, my buddy thinks he can get it now, much appreciated
brlrace is offline
post #7 of 46 (permalink) Old 04-06-2010, 11:32 PM
joshmccln's Avatar
hey kinda new here and seen that this was a recent post while yall were on the subject of axle removals i was gonna see if one of yall might know what could be the problem with gear oil pouring out of the dust seal any advice helps just got the four wheeler is a fourtrax 300 but its a 99 figured there aint that much difference
joshmccln is offline
post #8 of 46 (permalink) Old 04-07-2010, 12:04 AM
Which dust seal are you talking about? Are you talking about the dust seal in the rear brake drum cover? If you are, the inner seal in your differential case is leaking. And if that seal is leaking, then your axle bearings are probably bad, too.
post #9 of 46 (permalink) Old 04-07-2010, 11:51 AM
joshmccln's Avatar
yea im talking about the rear brake drum dust seal well i been lookin around trying to find a inner seal but cant find it even on cheap cycle and they got most everything already have the bearings and new dust seal
post #10 of 46 (permalink) Old 04-07-2010, 12:35 PM
Here is a link to Riva online parts finder:
Rivamotorsports.com's 1999 Honda ATV TRX300FW FOURTRAX 4X4 Parts List
#31 and #32 are the seals that you need. #32 is the one that's letting it leak into the axle tube housing and letting it run out the brake cover dust seal.
