2002 foreman rubicon 500 wont pull - Honda ATV Forum
post #1 of 17 (permalink) Old 07-22-2012, 07:58 PM Thread Starter
dieseldog558's Avatar
Smile 2002 foreman rubicon 500 wont pull
i just bought a 2002 honda 500 rubicon,with key on,the screen displays the gear selection properly,like it has no problems,when you start it,the screen flashes d1 d2 and the two dashes,just a constant flash and it wont move,when you try to rev it up it sounds like the engine is bogging down like its in gear but its not,only thing i have checked is oil psi,it seems ok,,,,please any help is greatly appreciated
dieseldog558 is offline
post #2 of 17 (permalink) Old 07-23-2012, 08:59 PM Thread Starter
Exclamation
ANYONE HAVE ANY SUGGESTIONS???? SURELY SOMEONE........all help is really appreciated
post #3 of 17 (permalink) Old 07-23-2012, 10:14 PM
fourwheeledfatkid's Avatar
Sounds like you may have an issue within the auto transmission unit.. I hope I am wrong but I've got an 03 rubicon with a slipping clutch (I haven't had time to fix..) It will move so I would say your problem wouldn't be there. Not to sound too basic but does the bike free roll? No chance of a locked up front or rear end? I would also check the solenoid that controls the gear selection. Here is a link to a full service manual. http://www.hondaatvforums.net/forums...all-years.html
Hopefully some of this may be useful to you.
fourwheeledfatkid is offline
post #4 of 17 (permalink) Old 07-24-2012, 06:59 PM Thread Starter
Unhappy
Well i never did get it to shift,so i decided to drain the oil and check for metal,needless to say the oil filter and oil are FULL of metal,not what i wanted to see,..any thoughts why i have metal and it wont pull and logging code 5?????
post #5 of 17 (permalink) Old 07-24-2012, 07:58 PM
Liked: 54 times
Best guess without seeing it personally would be clutch related,or tranny related...Change the oil,and filter,run it in neutral for a few minutes to warm the engine up,then use the manual shift handle to shift the transmission into gear...(after safely jacking the whole atv up off the ground)...See if it turns the tires,or what it does,,,
Deeperinthabush is offline
post #6 of 17 (permalink) Old 07-24-2012, 08:03 PM Thread Starter
Unhappy
thanks for the info......it dont have the manual shifter...it is auto with the esp,d1,d2...
post #7 of 17 (permalink) Old 07-24-2012, 08:03 PM
I've never seen a trans unit go down but that is kinda what is sounds like. It's basically a form of a hydraulic piston pump that powers a hydraulic piston motor.. If the oil filter failed and trash got into the pump or drive motor it could be bad news.
post #8 of 17 (permalink) Old 07-24-2012, 08:06 PM Thread Starter
yeah it very well could be bad news..i'm sure the metal is why it isnt shifting....makes me so mad to find this...lol
post #9 of 17 (permalink) Old 07-24-2012, 08:08 PM Thread Starter
plus...i have found that the control motor will only turn the reduction geat like 1/4 inch...cant get it to move any further...tried to rotate with screwdriver...didnt help
post #10 of 17 (permalink) Old 07-24-2012, 08:09 PM Thread Starter
reduction gear...sorry
