02-19-2010, 08:35 PM
#11 (permalink)
Member #1964
Originally Posted by shadetree
you probally have already checked this..butttttt....did you check to make sure you grounded your coil ??..see if you missed connecting the ground wire to the coil by any chance.
not sure what you mean by this....
02-19-2010, 08:43 PM
#12 (permalink)
Your ignition coil should be grounded by one of two ways.
(1) It should have two wires going to the coil. One is a ground and one is a positive.
(2) If there is only one wire(positive) going to the coil, then, the coil grounds by bolting to the frame.
02-19-2010, 08:51 PM
#13 (permalink)
Member #988
It should be a green wire. or green with a red strip
www.bbnradio.org
Our rides
1995 Wrangler
2004 Ford Explorer
2004 Recon 250
2009 Troy Built Lawn Tractor
and a 110 Pink Panther
www.trxforums.com
02-19-2010, 09:19 PM
#14 (permalink)
you are correct helmut..some coils have two wires going to them..one goes to the coil..other goes through the coil bolt hole to the frame, and on some bikes..they have both wires going straight to the coil :-)
06-14-2010, 02:32 PM
#15 (permalink)
Member #1964
Ok...This thing is back to being possessed...
I got this thing running PERFECTLY and gave it to my 10 year old nephew for his birthday a few months ago...Dont know who was more excited to have it...him or his dad. They rode the heck out of it in their yard and street...ran and started perfect everytime. 1 pull and it was purring... Well here is the kicker...
My brother brings his atvs in every year to a shop that goes through them ..basically lubes...and repairs any trivial thing that needs attention. HE BROUGHT THIS HONDA 90 TO THEM AND ASKED IF THEY COULD FINE TUNE THE CARB...AS THE PLUG WAS A BIT DARK AFTER RUNNING IT FOR A FEW HOURS.
THEY (the shop) drove it off the trailer....THEY drove it around their lot...THEY drove it around their offroad course...then they ordered a new carb kit. That was 2 months ago.. Somehow they did something and guess what... IT NO LONGER HAS SPARK!
I have told my brother it is their problem as he handed them a running machine.... and they need to undue whatever they messed up.
ANY THOUGHTS?? AM I BEING UNREASONABLE?
06-14-2010, 03:53 PM
#16 (permalink)
i would say..who ever had it last..needs to fix it..this is me though..as i know..working on these bikes..don't come cheap.
06-14-2010, 05:33 PM
#17 (permalink)
Member #417
Agree^^^^ I would make thm fix what they screwed up.
1991 TRX 250X
400EX carb, UNI filter,
Secret engine ingredients
FMF Power Core 4 full exhaust,
400EX front suspension
450R front shocks,LT250R rear shock
Custom oil cooler
check it out
http://www.hondaatvforums.net/forums...-makeover.html
06-14-2010, 05:38 PM
#18 (permalink)
Yeah, it sounds reasonable for them to fix it, since they were working on it. I would try to get them to fix it, but at the very least, I would try to get them to supply the labor.
06-14-2010, 10:07 PM
#19 (permalink)
Member #1964
I agree...if a part went kafloeey...I could see paying for that.... but they should at least troubleshoot it and make it run....still sucks...as I put a lot of time, money , and effort into this 90 for the kid.... and now it sits in a shop.... not even being worked on....and my brother....afraid to confront them....
honda 90 no spark, honda trx 90 neutral safety switch, honda trx 90 neutral switch, honda trx90 stator specs, how to test neutral safety switch honda trx 90, trx 70 neutral switch, trx 90 magneto, trx 90 neutral safety switch, trx 90 no spark, trx 90 stator, trx90 stator, trx90 stator test
