84 200s ATC Wont start!! - Honda ATV Forum
post #1 of 11 (permalink) Old 06-28-2012, 12:26 PM Thread Starter
wallr02's Avatar
Alright guys I have a buddy with a 84 200s atc and he just rebuild the top end and carb. Everything is stock. It wont start or anything its got spark, now he brought it over to me to get it timed right, I timed it the pulse generator is lined up right, I just dont get it, also when we try to pop start it, it goes into gear then if you rock it to go into another gear it pops out of gear, so we finally got it into other gears by being real gentle and tried pop starting it in 2 and 3rd gear, but if you turn the wheel even slightly it pops out and acts like its in neutral but its not bc we still have to shift it to get it back to neutral. But Im still baffled on it not starting, how do i check the cdi, or unflood it if its flooded out or is there something else Im not thinking of... Sorry if my whole description is wacked out im just really irritated with this thing, so any thoughts would be greatly appreciated, also I hate meters so if tell me to check any voltages explain what setting and where to stick the prongs.. Thanks Guys.
wallr02 is offline
post #2 of 11 (permalink) Old 06-28-2012, 02:15 PM
HondaGav's Avatar
Liked: 64 times
Check the cylinder compression, then check if it's even getting gas to the cylinder.
-2007 King Quad 450 (Work Horse)
-1984 Honda TRX200 (Donor)
-1989 Skidoo Mach 1 (Play Toy/Winter Headache)
-1966 Series IIA Land Rover (Major Project)
HondaGav is offline
post #3 of 11 (permalink) Old 06-28-2012, 04:34 PM Thread Starter
wallr02's Avatar
compression is good and the plug is wet every time Ive pulled it out. okay so what should the gap be bc i put it at .026 thats what the manual says anyways
wallr02 is offline
post #4 of 11 (permalink) Old 06-29-2012, 06:47 AM Thread Starter
wallr02's Avatar
Does anyone have any ideas, Im at a loss I adjust the valves too, this thing just does not want to start. Plus it doesnt help with the gears acting weird and slipping out...
wallr02 is offline
post #5 of 11 (permalink) Old 06-29-2012, 09:41 AM
HondaGav's Avatar
Liked: 64 times
Trey replacing the spark. My bike was doing that so I swapped the plug and it started 2nd pull.
HondaGav is offline
post #6 of 11 (permalink) Old 06-29-2012, 01:49 PM Thread Starter
wallr02's Avatar
Yeah tried 3 different ones and nothing still.
wallr02 is offline
post #7 of 11 (permalink) Old 06-29-2012, 06:28 PM
Trips's Avatar
What is the spark like?
I had a 200 and it was a pita to bump start, they go into a neutral state just like you said, I wouldnt worry about that.
Is the spark nice and blue? Or just yellow?
Trips is offline
post #8 of 11 (permalink) Old 06-29-2012, 08:39 PM
yamahasucks's Avatar
try a small spray of ether through the carb and see if it lights if it does then you know its a fuel issue and the carb probably needs cleaned and as for popping out of gear it could be a shift drum issue or bent shift fork
2004 400ex
yoshimura slip on
uni filter
426 kit
moose bars
dg bumper
msr clutch
itp c-series rims
yamahasucks is offline
post #9 of 11 (permalink) Old 06-30-2012, 08:25 AM Thread Starter
wallr02's Avatar
The spark is blue, and ether I never thought of that ill try that and let you know.
wallr02 is offline
post #10 of 11 (permalink) Old 06-30-2012, 08:26 AM Thread Starter
wallr02's Avatar
oh one more thing i took off the filter and there was gas all in the tube and filter i dont know why
wallr02 is offline
