Oil Filter. - Honda ATV Forum
post #1 of 8 (permalink) Old 06-25-2012, 09:02 PM Thread Starter
HondaGav's Avatar
Liked: 64 times
Oil Filter.
On my 1984 Honda TRX 200, Which way around does the oil filter go in. I got it started it and ran it 15 minutes until it went crunch. I drained the oil and it had metal shavings in it. I figure the guy I bought it from had the filter backwards and starved the engine of oil.
Also Where do I find a new air filter, Mine has nothing at the moment.
-2007 King Quad 450 (Work Horse)
-1984 Honda TRX200 (Donor)
-1989 Skidoo Mach 1 (Play Toy/Winter Headache)
-1966 Series IIA Land Rover (Major Project)
HondaGav is offline
post #2 of 8 (permalink) Old 06-25-2012, 09:05 PM
Josh's Avatar
rockymountainatvmc.com
as for the oil filter the side with the o ring should go towards the motor if its anything like the quad I have
Josh is offline
post #3 of 8 (permalink) Old 06-25-2012, 09:35 PM
Liked: 24 times
The '84 Fourtrax 200 doesn't have an oil filter, just a screen. But didn't you say that it had a 250 engine in it? If that's the case, the rubber grommet goes out toward the oil filter cover. The spring sits behind the oil filter against the crankcase.
post #4 of 8 (permalink) Old 06-25-2012, 09:37 PM
Liked: 24 times
Which quad do you have? On most Honda quads, the rubber grommet faces outward against the oil filter cover.
post #5 of 8 (permalink) Old 06-26-2012, 07:38 PM Thread Starter
HondaGav's Avatar
Liked: 64 times
It's the 200cc Model but it is an '86 instead of an '84 engine.
When I bough it the screen in the drain plug had the rubber on the inside with the spring out towards the drain plug. Is that right?
HondaGav is offline
post #6 of 8 (permalink) Old 06-26-2012, 10:02 PM
Liked: 24 times
Yeah, that keeps confusing me because they only sold the Fourtrax 200 for one year (1984) in the US. I keep forgetting they sold it longer in Canada. And yeah, that's right. Screen goes in first and then the spring and then the drain plug.
post #7 of 8 (permalink) Old 06-29-2012, 09:49 AM Thread Starter
HondaGav's Avatar
Liked: 64 times
Thanks Helmut.
HondaGav is offline
post #8 of 8 (permalink) Old 06-29-2012, 09:51 PM
Liked: 24 times
You're welcome.
