02-09-2010, 07:29 AM
#1 (permalink)
Member #1961
07 Trx 450er Blowing battery fuse?
Hey, I have a 07 450er and it keeps popping the 20 amp fuse on the battery..thought it was a bad starter switch replaced it and still doing it to me...what i have noticed is that it seems to blow it either going into gear or going back to neutral..Any suggestions to where i should focus on?
Thanks!
02-09-2010, 07:34 AM
#2 (permalink)
Member #126
First check you wireing and make sure none of the wire is exposed. I had a similar issue and I had a wire that was worn through. Also check your grounds and put delectric grease on all your connections and plugs.
02-09-2010, 07:39 AM
#3 (permalink)
Member #1961
cool, will do...thanks
02-09-2010, 07:45 AM
#4 (permalink)
May be a short in the neutral light circuit, if it blows going in and out of neutral.
02-09-2010, 07:46 AM
#5 (permalink)
Member #126
No problem!! Best of luck!
02-09-2010, 07:52 AM
#6 (permalink)
Member #618
You said you already checked the start button on the bars? I had the exact same issue on my 07 TRX450ER and it was the spring in my start button collapsed.
I don't want to arrive at the Pearly Gates in a well preserved body... I want to slide in sideways screaming "NOW THAT WAS A F'ING RIDE"
02-09-2010, 07:56 AM
#7 (permalink)
Member #1961
yea that light was a thought maybe ill pull that off see if it stops with that inop...Yea i had the starter button missing from the switch so i put a new unit on and had no luck
02-09-2010, 08:01 AM
#8 (permalink)
It might not blow the fuse with the light out, but I don't think it will start and run unless the neutral light circuit is intact. I would check the neutral light socket that the bulb goes in, also. I could be wrong about that, though.
02-09-2010, 08:06 AM
#9 (permalink)
Member #1961
It might not blow the fuse with the light out, but I don't think it will start and run unless the neutral light circuit is intact. I would check the neutral light socket that the bulb goes in, also. I could be wrong about that, though.[/QUOTE]
lol..im pretty much lost on what it can be cause its happening in such a odd situation...i appreciate all the quick help
02-09-2010, 08:09 AM
#10 (permalink)
Member #618
I am going to see my mechanic today and try to get some ideas for you.
| Visitors found this page by searching for these keywords: |
2009 450er wiring diagram, 07 trx450er starter button doesnt work
» Site Navigation |
» Honda Forums
