fourtrax valve adjustment question - Honda ATV Forum
Old 05-04-2012, 04:46 AM   #1 (permalink)
brewster2's Avatar
Member #17931
View brewster2's Photo Gallery(0)
I am checking the valves on my 86 350 4x4. When I do everything the shop manual tells me to, there doesn't seem to be any play in the rocker arms either in the intake or exhaust sides. Any ideas?
Thanks in advance.
brewster2 is offline   Reply With Quote
Old 05-04-2012, 11:50 AM   #2 (permalink)
Member #7607
View Manny's Photo Gallery(0)
Liked: 162 times
Rotate the crank another revolution. your probably on the exhaust stroke instead of compression.
HONDA parts for sale
Old 05-04-2012, 11:51 AM   #3 (permalink)
Member #7607
Liked: 162 times
watch your intake valves, watch them rise, then when they seat you are on the compression stroke. make sure you are at TDC and you have a little play in the rocker arms. then set your valves.
Old 05-04-2012, 12:04 PM   #4 (permalink)
brewster2's Avatar
Member #17931
Thanks Manny, but I've already tried that and there isn't any play no matter what i do with the crank. The bike for the most part runs very well, there was just some light clicking coming from the top end so I thought I would adjust the valves.
Old 05-04-2012, 01:01 PM   #5 (permalink)
Jabman's Avatar
Member #16583
View Jabman's Photo Gallery(0)
If you have 0 play that could be a bad thing.
As manny said.
Rotate the motor till you see the intake side start to rise, then peer your eye into the hole.. and align TDC , wiggle or no wiggle.. crack them loose and get them to specs..
and yes its possible for a valve tappet to tighten its self down to 0 clearance, the bike will run but poorly.
Jabman is offline   Reply With Quote
300 fourtrax vavle adjustment
fourtrax 300 valve adjustment
honda 300 fourtrax valve adjustment
honda 300 fourtrax valve specs
honda fourtrax 300 valve adjustment
honda fourtrax valve adjustment
how to adjust valves on a honda fourtrax 300
how to adjust valves on honda 300 fourtrax
how to adjust valves on honda fourtrax 300
intake valve and exhaust vale setting for1998 honda300 four trac
ticking after adjusting valves on a 1998 honda 300 fourtrax
valve adjustment honda fourtrax
