honda trx 420 - Honda ATV Forum
Old 04-16-2012, 04:06 PM   #1 (permalink)
outbackmac's Avatar
Member #17881
View outbackmac's Photo Gallery(0)
honda trx 420
I changed the oil and when i filled it up it was completely full up to the rim of fill tube is this correct? it calls for 3.8 qts but it seems like to much
outbackmac is offline   Reply With Quote
Old 04-16-2012, 04:16 PM   #2 (permalink)
Melatv's Avatar
Member #11544
View Melatv's Photo Gallery(0)
Liked: 116 times
No you will to siphon oil out until it read right on the dip stick.
25" Kenda K587 Bear Claws HTR
2500 Runva Winch
Melatv is offline   Reply With Quote
Old 04-16-2012, 09:26 PM   #3 (permalink)
bobs330's Avatar
Member #8144
Welcome to the forums from OK. On an oil change with filter, its 3 quarts, not 3.8. It is overfilled, just syphon some out and good to go.
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
Old 04-16-2012, 11:07 PM   #4 (permalink)
Unless it's the auto tranny model. The auto tranny model holds 3.8 quarts. But yeah, it's overfilled if it's all the way to the top.
Old 04-16-2012, 11:08 PM   #5 (permalink)
And welcome to the forums.
Old 04-17-2012, 09:58 AM   #6 (permalink)
outbackmac's Avatar
Member #17881
oil capacity
i have the trx that can either run ib AUTO or manual without a clutch, manual says 3.8 and i put most of the gallon in so i guess i will drain a little out
Old 04-17-2012, 07:57 PM   #7 (permalink)
bobs330's Avatar
Member #8144
Ok yeah that would be overfilled. I forget about the AT sometimes and that they are different specs.
AMS Swamp fox tires
Superwinch Terra 25
Moose rear bumper
2010 trx420te oil capacity
2011 honda rancher 420 oil capacity
2014 trx420 oil capacity
honda 420 rancher oil capacity
honda 420 trx oil volume
honda trx 420 oil
honda trx 420 oil capacity
honda trx420 oil capacity
oil capacity trx420
trx420 oil capacity
