04-14-2012, 06:46 PM
#1 (permalink)
Member #16486
foreman all wheel drive???
Hey has anyone ever converted a 2002 450 foreman to all wheel drive instead of only 1 in the front ?
04-14-2012, 07:33 PM
#2 (permalink)
Member #14099
I don't think it would be a very good idea due to the steering would be extremely hard.
04 250ex
06 yamaha Wolverine 450
03 recon
04-14-2012, 07:49 PM
#3 (permalink)
Member #16486
I don't mean to stay on all the time. What I mean is normaly when put in 4x4 both front tires don't spin at the same time, is there anyway to make it diff lock?
04-14-2012, 08:26 PM
#4 (permalink)
Member #8144
Someone willo be able to help, deeperinthabush will be able to help also.
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
04-14-2012, 08:46 PM
#5 (permalink)
Member #7607
You can install a detroit gearless locker and that will give you the full diff lock that you want.....what would make it even better is if you had a warn 4-2-4 installed....that way you could have full time diff lock but you wouldnt be struggling to steer the bear all the time in 4wd
Realtree AP Plastics
Warn 2000 Lb. winch
Sedona Ripsaw tires
2013 Can Am Commander 800 XT
Roof, F&R Windshield's, 27 inch bighorn's
*Download your FREE service manual BELOW*
04-14-2012, 09:59 PM
#6 (permalink)
X2 on what Manny said above...Believe it or not,having a locker in the front doesn't really make the steering much,if any harder as the tires only have a minimal contact patch on the ground,and the only time I ever had more steering effort required was in deep ruts,and deep mud,against a rock,or in a washout which required extra effort anyhoo due to the large tires,and resistance of the mud,rocks,dirt,and ruts...Having a locker in the front axle will cause the vehicle to want to travel straight forward rather than turning though,and will require a much larger turning area,or turning radius as the bottoms of the tires turn at the exact same speed regardless of the traction on the either side...Must be why no manufacturer installs a full time locker in front...Hence the diff lock buttons,and switches on other brands...High Lifter makes a 40 buck front full time locker which is two toothed shims that fully ,and permanently lock the front axles together to the diff,and is only recommended for full bore mud machines...Pulling/modulating the front brakes just enough to cause the free spinning tire on an open diff,or limited slip like Hondas will get you as far as a locker will when it forces the free spinning tire to slow down,and the diff to apply power to the one with traction as long as one doesn't pull the brake lever too hard....
04-14-2012, 10:21 PM
#7 (permalink)
He wouldn't need a Warn 4-2-4 because the '02-up Foreman has selectable 2wd/4wd.
04-14-2012, 10:36 PM
#8 (permalink)
Member #7607
Whoops. i missed that part.
Warn 2000 Lb. winch
Sedona Ripsaw tires
04-14-2012, 11:02 PM
#9 (permalink)
Member #10220
Can I get a locker for a new Rincon also
04-14-2012, 11:28 PM
#10 (permalink)
Why yes,yes you can have your locker,and go deep too Falcon>>>> High Lifter Products - HONDA TRAX LOCK SPOOL LOCKER
08 honda foremam all wheel drive, 1986-forman-four wheei drive honda-atv, 2001 honda rubicon foreman 500 awd, 2012 honda foreman 500 4 wheel drive does not spin all 4 tires, convert honda foreman to two wheel drive without warn, diff lock honda rubicon, does honda make an all wheel drive foreman, honda foreman 400 hard to turn, honda foreman 450 all four wheel drive, honda foreman 500 diff lock selectable 2wd or 4wd, honda foreman all wheel drive, make a foreman 2 wheel drive
