2001 Honda Recon 250 Clutch Slipping - Honda ATV Forum
post #1 of 9 (permalink) Old 04-07-2012, 11:42 PM Thread Starter
lilhunter1982's Avatar
I have a 2001 Honda Recon 250..Ive put a new clutch basket in it and a new one way clutch bearing.. when i drive on the road it feels fine but when im on a trail and really crank down on the gas i feel the clutch slipping... i did not replace the sentrifugal clutch pads...do you think it is the sentrifugal pads?
lilhunter1982 is offline
post #2 of 9 (permalink) Old 04-07-2012, 11:51 PM
When you replaced the clutch basket, did you replace the clutch discs, too? I'm assuming that's what you meant. If so, then yes, it could be the centrifugal clutch slipping.
post #3 of 9 (permalink) Old 04-08-2012, 10:24 PM Thread Starter
yeah thats what I ment..sorry.. i will say when i seen the centrifugal clutch pads..that they looked like burnt up bricks.. chipped away
post #4 of 9 (permalink) Old 04-08-2012, 11:37 PM
Yeah, it sounds like they've been slipping. You can measure how much lining is left on them. The service manual lists the specs. Also, check the inside of your clutch drum for excessive grooving where the clutch blocks engage.
post #5 of 9 (permalink) Old 05-12-2012, 03:08 AM Thread Starter
well i figured out the problem... i mean i figured that its the clutch plates slipping.. silly me put motor oil in my atv insted of atv oil.... so now im replacing the discs once again
post #6 of 9 (permalink) Old 05-12-2012, 10:48 AM
Liked: 54 times
Soak the new discs in wet clutch approved dino oil for 24 hours prior to installing them,and scuff the steels with a scotch brite pad before you put it all back together,or it'll likely slip again,and not hold as well,or as long as it should...More than likely the slipping new plates caused a glaze to build up on the steels,and it has to be removed,or you'll be on another set of discs pretty quickly...
Deeperinthabush is offline
post #7 of 9 (permalink) Old 05-12-2012, 10:13 PM
X2, that's how I do it, too.
post #8 of 9 (permalink) Old 05-16-2012, 12:25 AM Thread Starter
I ordered new discs and new steels...they should be in today...i also bought honda 10/40 atv oil.... i had already planned on soaking the plates for 24 hrs...do i still need to scuff the new steels? im figuring yes
post #9 of 9 (permalink) Old 05-16-2012, 01:04 AM
You wouldn't have to scuff the new plates, but it wouldn't hurt anything either.
