04 rancher won't shift - Honda ATV Forum
post #1 of 13 (permalink) Old 04-07-2012, 10:50 PM Thread Starter
Tecaterunner's Avatar
So here we go I got a rancher in trade for a blaster wouldn't shift so what I thought would be an easy fix was not so. Had to rebuild the tranny now it will shift with the manual over ride. But it will not shift with the electric shift I have no error codes and I've been chasing it for 2 days every thing has power but nothing any ideas on what it could be. It is a 350
Tecaterunner is offline
post #2 of 13 (permalink) Old 04-08-2012, 10:13 AM Thread Starter
Ok wondering if any one has a picture of the ecu connector I think who ever I got it from had it apart and it's not hooked up correctly. Is there any one in Virginia beach area that has one of these that I could possible look at to diagnose my issue. Thanks.
post #3 of 13 (permalink) Old 04-08-2012, 10:47 AM
melsman's Avatar
Liked: 3 times
Hi Tecaterunner,
I can't help you directly in the area of the connector pin-out, but the service manuals usually have descriptions of which pins go where in the connector. Do you have a manual? If not, click the link in my signature and you can download one for your wheeler.
Good luck.
Melsman
2005 Rancher 400FA AT
Superwinch LT2000
24" Bearclaws
SuperATV disc brakes w/caliper flip
Kolpin front and rear trail boxes w/rack & fuel packs
2005 TRX400EX
13T front sprocket; EZ Pull Clutch
PRM full skid plates and side bars
2003 TRX250EX
22" Bearclaws on rear
DG Alloy Nerf Bars
melsman is offline
post #4 of 13 (permalink) Old 04-08-2012, 11:43 AM Thread Starter
Yea I have one but it just keeps running me in circles says do this then do this. But then I check a wire that should have power it don't then when I go through again it does it's getting frustrating to say the least
post #5 of 13 (permalink) Old 04-08-2012, 04:42 PM Thread Starter
Ok Im getting closer to a fix I think I have checked the book and I've checked every wire have good continuity shift motor will shift when I hook it straight to 12 volt and the book says temporary failure but yet I don't have any power to the shift motor when hooked up to the ecu but I have great continuity. This ecu came from a Honda shop that they used for testing wish I had another to test be cause my old one was doing the same thing any ideas guys
post #6 of 13 (permalink) Old 04-08-2012, 05:33 PM
meats's Avatar
give this a try it worked on my wifes 01 350. i had it at a local honda shop and they tested angle sensor and all that and all was good, i took the digital display" not sure what they call it" but i took that apart and it looked like some corrosion started so i took a brass wire brush and cleaned all the contacts and bam works like a charm for past 2 yrs. for the hr it would take its worth checking it out. good luck
meats is offline
post #7 of 13 (permalink) Old 04-08-2012, 05:38 PM Thread Starter
I will give this a try I have nothing to loose at this point I just really don't want to pay 80 an hour to trouble shoot it. Thinking I need to get my 85 250sx back from my dad
post #8 of 13 (permalink) Old 04-08-2012, 06:10 PM Thread Starter
Tried it every thing looks good to me it's so frustrating I could scream someone has had to have had this issue before
post #9 of 13 (permalink) Old 04-08-2012, 07:08 PM
slincolnn's Avatar
Welcome to the forum.Helmut will be along shortly or you could pm him he is outstanding with honda atvs.
07 Foreman 500
04 250ex
06 yamaha Wolverine 450
03 recon
slincolnn is offline
post #10 of 13 (permalink) Old 04-08-2012, 07:38 PM Thread Starter
Thanks for the welcome I'll wait if he don't come around by tomorrow I will pm him
