leaking oil? - Honda ATV Forum
post #1 of 9 (permalink) Old 03-25-2012, 09:10 PM Thread Starter
HondaGuy300's Avatar
leaking oil?
every time i take my fourtrax 300 in water i see oil in the water. i check the oil but no water. why is it leaking? where is it coming from?
Honda Rancher 420 4x4 ES w/ EPS (red)
completly stock (for now)
[CENTER]gone but not forgotten: Honda Fourtrax 300 4x4
HondaGuy300 is offline
post #2 of 9 (permalink) Old 03-25-2012, 09:50 PM
Liked: 225 times
How's your oil level? Do you see a steady decrease after rides?
Manny is offline
post #3 of 9 (permalink) Old 03-27-2012, 06:52 PM Thread Starter
stays about the same, just a little below the full line. i know i need to put some more in it. would a worn out front bearring have anything to do with it?
post #4 of 9 (permalink) Old 03-27-2012, 07:42 PM
jkhuntin's Avatar
Liked: 19 times
Diff. grease??? Check the fluid level and for water in your front and rear diffs.
2004 Rincon
2" lift
27" mudlites, ITP SS212's
Mud bike
2013 Rancher 420 AT.
jkhuntin is offline
post #5 of 9 (permalink) Old 03-27-2012, 09:26 PM
Liked: 225 times
Are we talking about motor oil or diff. fluid? I'm confused LOL
Manny is offline
post #6 of 9 (permalink) Old 03-27-2012, 10:46 PM
jkhuntin's Avatar
Liked: 19 times
I was just thinking that if he's not showing any water in the oil and he's not leaking any oil, it could possibly be a leaking diff. that is causing the film on the water. Just a thought. Also to the OP, when's the last time you cleaned the motor? Could be residual, do a thourogh cleaning of the motor and then watch for leaks, it dosen't take much oil to cause a large film spot in water.
2004 Rincon
2" lift
Mud bike
jkhuntin is offline
post #7 of 9 (permalink) Old 03-28-2012, 12:00 AM
X2, this is what I'm thinking, too. It doesn't take much oil to leave a film on the water.
post #8 of 9 (permalink) Old 03-28-2012, 06:59 AM
Dan G's Avatar
Liked: 6 times
Even a little gas will do that too... run it hard, then park it on dry blacktop for a few minutes and let it idle, if it doesn't leak anything I would assume its just some left over residue on the engine...
Dan G is offline
post #9 of 9 (permalink) Old 03-28-2012, 06:31 PM
HardHeadHommie's Avatar
it may just be residual
Good Evening and Hello.
2000 Honda Fourtrax 300
2wd PIAA 35 watt headlights
Stock Rancher wheels and tires for now.
Red Rhino Lined
Strong Quad
HardHeadHommie is offline
