carb leaking from overflow tubes - Honda ATV Forum
post #1 of 9 (permalink) Old 02-27-2012, 08:44 AM
BongRipper
Guest
BongRipper's Avatar
Posts: n/a
how can i stop my carb from leakin for the overlfow tubes i really need to fix it because gas is sky high and its gonna get gettin higher and higher pretty soon.and it doesn't even leak form the TUBE it leaks from where the tube goes and the gas is drippin on my starter
post #2 of 9 (permalink) Old 02-27-2012, 08:51 AM
agdempsey's Avatar
Is it leaking from the hose at the petcock where you turn the gas on and off? Is the hose cracked? Is it the right size hose?
1986 TRX 250 FOURTRAX
agdempsey is offline
post #3 of 9 (permalink) Old 02-27-2012, 09:02 AM
ggaspo13's Avatar
- if it's ur overflow tube then turn off the gas at the petcock. then go into your carb and clean it, sounds like a sticky float.
- if your petcock valve is leaking, drain all of the gas out of the tank, remove the petcock and clean, you should also inspect the rubber seals bc they may need to be replaced if your leaking around the petcock.
- inspect your fuel lines for crack or leaks. replace if necessary
2002 LT80 - 7 yr old sons
2005 Raptor 50 - 5 yr old sons
1982 Yamaha PW50 - Xmas gift for the boys (can't wait to upgrade them to a crf50 or 70)
Projects
1983 Suzuki LT125
2002 Yamaha Bear Tracker 250 SOLD
2001 300ex SOLD
1996 300ex SOLD (Brought me to the forum)
Greg
ggaspo13 is offline
post #4 of 9 (permalink) Old 02-27-2012, 09:12 AM
ggaspo13's Avatar
just read your other post and you said you soaked the petcock in carb cleaner. I'm assuming you did this without removing the rubber seals and they were ruined by this. You need to remove anything rubber before soaking with carb cleaner
Projects
1983 Suzuki LT125
2001 300ex SOLD
Greg
ggaspo13 is offline
post #5 of 9 (permalink) Old 02-27-2012, 09:30 AM
CR1976's Avatar
If its coming from the overflow tube on your carb I would say your float is sticking or is bad. You might want to try cleaning the bowl out. It could also be the bowl gasket leaking and its running down the outside of the overflow tube. That's what mine was doing. I replaced the bowl gasket and it stopped.
1999 TRX 400EX
Renthal Bars
Monsoon Seat
White Bros. Head Pipe
FMF Silencer
Uni Air Filter No Lid
Curtis Sparks Timing Key
Lone Star Carrier
E Brake Block Off
170 Main Jet
42 Pilot Jet
Ambush Tires
1999 TRX 300EX
FMF Silencer
Uni Air Filter
Kenda Bear Claws Out Back
This Is My Wife Shana's Quad
CR1976 is offline
post #6 of 9 (permalink) Old 02-27-2012, 09:35 AM
BongRipper
Guest
BongRipper's Avatar
Posts: n/a
Click the image to open in full size. ive done cleaned my carbs
post #7 of 9 (permalink) Old 02-27-2012, 12:06 PM
CR1976's Avatar
I would replace the float and the needle valve. I would say the float has a hole in it or the needle valve is worn, crusty, or pitted. I would also replace that clamp and the tube on the overflow. Use a regular hose clamp. The clamp that's on there is probably why the gas is running down the outside of the tube.
1999 TRX 400EX
Renthal Bars
Monsoon Seat
FMF Silencer
Lone Star Carrier
E Brake Block Off
170 Main Jet
42 Pilot Jet
Ambush Tires
1999 TRX 300EX
FMF Silencer
Uni Air Filter
CR1976 is offline
post #8 of 9 (permalink) Old 02-27-2012, 12:45 PM
ggaspo13's Avatar
This doesn't mean that you got everything out
You also need to know exactly where the gas is coming from to properly diagnose the problem. Remove the overflow tube and make sure it's not blocked up. See if the gas is coming out of the overflow or like CR said between the bowl gasket and just dripping down to the hose. And as I said before don't use carb cleaner without removing all of the rubber gaskets/seals
Projects
1983 Suzuki LT125
2001 300ex SOLD
Greg
ggaspo13 is offline
post #9 of 9 (permalink) Old 02-27-2012, 03:08 PM
BongRipper
Guest
BongRipper's Avatar
Posts: n/a
i think ive got everything fixed im about to hit the trails and ill find out then
