02-22-2012, 11:06 AM
#1 (permalink)
Member #16355
2011 rancher electric shift problem
Have a 2011 electric shift rancher with 800 miles. Problem started when it would not shift into 5th gear sometimes and now it grinds in 4th gear and will not engage. It also grinds a little when it goes into reverse but will engage.. Anyone have any idea what the problem could be and how do I fix it?? Help Please my boys are going nuts without it!!!
02-22-2012, 11:41 AM
#2 (permalink)
sounds like the angle sensor to me...test the angle sensor.
02-22-2012, 05:48 PM
#3 (permalink)
Member #16201
Make sure you have plenty (full) of oil in your engine/transmission, and that it is the CORRECT type of oil. You can not use regular automotive motor oil with your Rancher. Rather, you must use oil that is formulated for motorcycles/ATV's with wet clutches. You can get Honda oil, or you can get synthetic oil from Mobil1 or Amsoil. I use the Mobil1 4T motorcycle oil and love it. Also, your oil should be full to the top mark on your dip stick. (The engine and transmission use the same oil).
*Foreman 500
*Rancher 420AT
*Rincon 680-Kimpex Bumpers, Cyclecountry Frontmount Plow, SuperWinch Terra, Synthetic Rope, Chainsaw rack, Mountaingear Pack, Handwarmers, VIP-Air Fairing/Windshield, BigHorn tires, STI Wheels, HL Springs, Garmin Oregon550 GPS. Mobil1-4T oil.
03-02-2012, 09:55 AM
#4 (permalink)
Member #16355
Along with the grinding in fourth, fifth and reverse, It also has a tapping sound while it is in neutral. The tapping sound is near where you put oil in the engine.
03-02-2012, 11:47 AM
#5 (permalink)
Member #16201
Have you checked your oil level? I'm also curious what a sample of your oil looks like. Understand that your engine oil is also your transmission oil. If it is low, your tranny won't work correctly. Pull out your dipstick and wipe the oil on your fingertip. Do you see any metalic particles? If so, then you'll need to visit your Honda dealer unless you're quite mechanically inclined. Keeping your oil up to the Full mark on your dipstick and changing your oil filters when necessary is essential when both your engine and tranny share the same oil. You should measure the oil on your dipstick by first removing the dipstick and wiping it off (clean). Then, set it in it's hole, but don't screw it down. Then, pull it back out and check the level. Last, but not least, you must use oil that is formulated for a wet clutch - NOT regular automotive oil.
PS: If your angle sensor was/is going bad (very unlikely), your ATV would simply stop and shut off. Bad angle sensors don't cause poor shifting and grinding gears.
*Foreman 500
*Rancher 420AT
03-02-2012, 11:17 PM
#6 (permalink)
Welcome to the forums. Have you tried adjusting the clutch freeplay? The clutch might not be completely disengaging when you shift.
2012 honda rancher how to shift into reverse, can you use synthetic oil in a honda rancher, does a honda rancher take synthetic iol, electric shift honda atv problem, electric shift honda rancher want shift into fourth or fifth gear, electric shift on atv, electric shift problems honda, electric vs auto shift on atv, fix electric shift on honda, gear shifting vs auto atv, honda atv electric shift problems, honda electric shift atv does not go into reverse, honda electric shift problems, honda es shift problums, honda rancher electric shift problems, how does electric shift work on honda rancher, how does the honda rancher auto shift work?, problems with honda atv electric shift, quad will not shift into reverse?, shifting problems on honda rancher
