pull starter dont work.... - Honda ATV Forum
Old 02-20-2012, 04:45 PM   #1 (permalink)
waterdog's Avatar
Member #16300
View waterdog's Photo Gallery(0)
i just got a 04 250es recon, was checkin and noticed the pull starter dont work, i pulled the rope and the engine doesnt turn,, but the rope returns fine,, is this a fairly easy job to remove the pullstarter to check inside?? is this common failure? thanks!!!
waterdog is offline   Reply With Quote
Old 02-20-2012, 05:36 PM   #2 (permalink)
Dan G's Avatar
Member #11269
View Dan G's Photo Gallery(0)
Liked: 6 times
Yeah its easy, and pretty common if its not used. If you keep pulling it over it may free up and work... The problem is the dogs inside the housing are stuck and not getting thrown out when you pull it over, probably corroded from sitting, if you take the recoil off the engine you should be able to spray some wd-40 on them, work them back and forth a few times and you should be good to go.
Old 02-20-2012, 05:39 PM   #3 (permalink)
Liked: 53 times
Try not to get any type of lube,or oil on the spring as it will ruin the spring by soaking into it,and the spring will lose it tension,or spring...You may wish to replace the rope while you're in there if it doesn't look solid as they tend to rot,and snap when ya use them...HD,or Lowes sells the right size,and type,just take the old with you to compare...
Old 02-20-2012, 05:43 PM   #4 (permalink)
Dan G's Avatar
Member #11269
Liked: 6 times
x2 on that, or you can be like me and take it off every other ride to re-tie a broken rope, lol.
Old 02-20-2012, 07:30 PM   #5 (permalink)
waterdog's Avatar
Member #16300
Thank u folks! Ill try that.....
2006 honda recon no tension on pull starter
2006 honda recon pull rope no tension
atv pull start repair
honda atc pull start just pulls out
honda rancher lubricate pull rope
honda rancher pull cord doesn't work
how to change the pull rope on a 2006 honda 250 tricks for
how to fix honda recon with no tension on motor when try to pull start
how to lube a pull starter spring
how to repair a pull rope on a honda 200xs
how to seal honda recon pull start
is there a rope start for a honda rubicon
