carb leaking - Honda ATV Forum
Old 02-20-2012, 09:06 AM   #1 (permalink)
BongRipper
Guest
BongRipper's Avatar
Member # View BongRipper's Photo Gallery()
Posts: n/a
carb leaking
trx300ex i cleaned the carbs and finally a got it runnin but now the carbs leak i stripped 2 screws on the float chamber and got em off so i replaced the screws with some higher quality screws but there not as long as the other ones but they still hold it together firmly.so this morning i noticed that gas was leaking out of my pilot screw it was a bubble of gas it wasn't bad but i still dont want gas leaking on my starter.what could be wrong i had the pilot screw turned 1 1/3 i tightened it a little bit but i dont know why its leaking?
Old 02-20-2012, 09:09 AM   #2 (permalink)
Liked: 1385 times
the pilot screw does not leak gas from the float bowl...your float is sticking..and gas is either leaking from the bowl gasket ?..or it's leaking from the over flow tube..and running down to the bottom of your carb..making it look like your pilot jet needle is leaking. fix your float needle.
Old 02-20-2012, 09:42 AM   #3 (permalink)
BongRipper
Guest
BongRipper's Avatar
Posts: n/a
i just checked my float needle it seems to be in the right place ill see what i can do ill let you know what goin on later on
Old 02-20-2012, 09:51 AM   #4 (permalink)
Liked: 1385 times
if your getting any gas running out of your carb...while it sits ???..then your float needle or the float needle seat is dirty...this is the only thing that let's fuel fill your float bowl up. it's either that ?..or your float bowl is not tight enough to the carb ?..or your screws are not tightening down enough ?..orrrrr...your float bowl gasket is bad..and not sealing ?..could just be from not getting tight enough ?.
87 honda foreman carb leak
atv carb is leaking after being replaced
atv carburetor leaking around scew
atv leaky carb
carb leaking out of bottom jet
honda gsx 390 carburetor bowl leaking
honda trx400fw carburetor leaking
leaking bottom screw on honda 200m three carburetors
leaky float chamber screw
why does atv carburetor leak
why does my atv carb leak fuel?
why does my carburetor leak gas
