02-10-2012, 10:24 PM
#1 (permalink)
Member #14289
To hone... or not to hone?
OK - starting my teardown of my '05 Rancher 400 FA AT engine, and was chatting with a friend who has rebuilt a few bike engines. He mentioned that some bike cylinders shouldn't be honed at all before installing new rings. I noticed the shop manual doesn't mention honing the cylinder when replacing the rings. But, in my very limited experience, it seems that the cylinder needs to be honed to get the new rings to seat properly... at least that's the case in the car engines I've overhauled.
So, back to my question... hone or no?
Melsman
02-10-2012, 10:57 PM
#2 (permalink)
hone it..lol..the new rings won't seat right if you don't hone the cylinder..then they will leak oil..compression..get the pic ?..lol.
02-10-2012, 10:59 PM
#3 (permalink)
and i have never...everrrrrrrrrr heard of anyone installing new rings without either a honing..or boring over..then a hone ??????..i'd like to know if these ppl you talked too..i wonder how many set's of rings they went through..before they decided to hone the cylinder ???????..lmfao.
02-11-2012, 12:34 AM
#4 (permalink)
Member #7607
+2 honing, i've never heard nore done otherwise.
02-11-2012, 07:55 AM
#5 (permalink)
Member #15733
Always hone a cyl when rings come out even if your putting same rings back in. Just do a very light hone if using same ring. Mic the cyl also every time the piston comes out just to make sure the wear is true and in spec. If you don't have a cyl Mic most machine shops (here) will Mic for free.
1986 TRX 250 FOURTRAX
02-11-2012, 10:17 AM
#6 (permalink)
Member #11909
i had a 230 quadsport the Dummies put in a new piston & rings didn't hone it and it smoked like a freaking freight train HONE It LOL
2004 400ex
yoshimura slip on
uni filter
426 kit
moose bars
dg bumper
msr clutch
itp c-series rims
02-11-2012, 04:32 PM
#7 (permalink)
Member #14099
The cylinder your not suppose to hone are nikasil plated aluminum cylinders because they say it will wear it off.Any cylinder with a steel sleeves need to be honed.Basically if it can be bored out then it needs to be honed.
01 Rancher 350 manual shift 4x4
27" Kenda claws
P&P head
04 250ex Wife's ride
Removed the baffle and rewelded spark arrestor back in,Jetted,Uni-filter
04 YFZ450
Port and Polish,12.5:1,Dyno-jet kit,K&N air filter with custom intake tube,Cam mod,Pro circuit Ti4,GYTR nerf bars.
01 400ex
Port and Polish
Pro Circuit T4
Uni-filter
Dyno-jet 160 45 pilot 2 1/4 turns out
Custom foot pegs
With many things to come
It is a good trail quad with a lot of torque
02-11-2012, 07:04 PM
#8 (permalink)
Member #14289
Ok - so let me be sure I understand this... because it's not very clear... I should hone the cylinder, right? LOL!
Thanks, Scott, for the composition I was trying to remember - nikasil. I figured my cylinder was a standard type, but I thought I'd verify. Especially since the shop manual mentions nothing about honing. (My vehicle shop manuals all go into detail about honing.)
Thanks everyone -
Melsman
02-11-2012, 07:23 PM
#9 (permalink)
Thanks everyone -
Melsman
scott is right as for cylinders that are nik plated...these CAN NOT BE HONED !!..they get bored out...over..then they have to be re-coated with a new coating of nik plating..most of these cylinders are in 2 stroke motors..at least the old school 2 strokes any way. i have seen alot of these types of nik plated cylinders in jet ski's.
02-11-2012, 08:00 PM
#10 (permalink)
Member #14099
I believe the new 450 race quads are also coated cylinders.
27" Kenda claws
P&P head
04 YFZ450
01 400ex
Port and Polish
Pro Circuit T4
Uni-filter
Custom foot pegs
400ex mic spec, boring honing honda 4trx cylinder, do i have to hone my 400ex cylinder, foreman piston honing, honda atv cylinder hone, honda foreman 400 nikasil, hone a cylinder on 2003 honda trx 250, hone a jet ski cylinder, honing atv cylinder, honing jet ski cylinders, how to hone a jet ski cyclinder, how to hone atv cylinder, how to hone cylinder on 99 honda 400ex, how to hone jet ski, how to hone the cylinder on 1998 250 honda recon, installing a new cylinder on my honda rancher, jet ski hone cylinder, new rings without honing, putting new rings without honing, should i hone my 2001 trx250ex before i rebuild it
