Old 02-10-2012, 09:36 AM   #1 (permalink)
2000honda300ex's Avatar
Member #8799
View 2000honda300ex's Photo Gallery(0)
72 Honda ct70 trailbike help
Working on 1972 honda trail ct70 bike for a guy...I can get no spark,feels like no compression, valves are opening as should. Well I guess what I need is a manual for it..I checked this site couldnt find one. I dont know how to get to the coil or nothing..new territory for me. Thanks
2000honda300ex is offline   Reply With Quote
Old 02-10-2012, 09:43 AM   #2 (permalink)
the spark plug coil is under the seat...inside the frame if i remember right ?..i found a micro fich for a ct70k1..it's not a repair manual..it just list the parts..amazingly..you still can get parts for it ?..although..i did not call to ask about them ?..lol.
Old 02-10-2012, 09:44 AM   #3 (permalink)
and the reason you could not find any manual's on here for it ?..is because it's considered a motor cycle...lol.
Old 02-10-2012, 10:19 AM   #4 (permalink)
Louk's Avatar
Member #8080
View Louk's Photo Gallery(0)
that motor uses points may need to file end gap and set to like 10 to 16 thousants low compression check valve adjustment may be tight set them to .003 thousants
Louk
all honda's 96 trx300fw,86trx200sx,01-trx90 86-trx70, 85-trx125,
4=84-85atc70's,85atc250sx,2=85-atc350x's,
82-atc110,82-xl80s,2=71-75-qa50's,66=dream150
Louk is offline   Reply With Quote
Old 02-10-2012, 10:31 AM   #5 (permalink)
agdempsey's Avatar
Member #15733
View agdempsey's Photo Gallery(0)
Ignition Timing Adjustment
CT70 And Mini Trail 50
1. Remove the left crankcase cover.
2. Rotate the flywheel counterclockwise to find the point where the breaker point gap is at maximum and check if the gap is correct using a thickness gauge.
3. The standard gap. is 0.012-0.016 in. (0.3-0.4 mm).
4. When adjustment is necessary, loosen the breaker locking screw and move the breaker base in either clockwise or counterclockwise direction to obtain the standard point gap setting.
5. After completting the breaker point gap adjustment, recheck the ignition timing. To perform the check, rotate the flywheel so that when the flywheel "F" timing mark is aligned to the timing index mark on the left crank case, the breaker points just begin to open.
1986 TRX 250 FOURTRAX
agdempsey is offline   Reply With Quote
Old 02-10-2012, 10:47 AM   #6 (permalink)
agdempsey's Avatar
Member #15733
Old 02-10-2012, 11:07 AM   #7 (permalink)
Member #8799
no I got spark BUT pretty sure what the problem is! I cleaned the carb pulled the neck off that connect carb and head..inside the head a bunch of foam! Yeah I know! HOW! ? I think someone pulled carb off put foam in to keep dirt out and forgot to pull the foam back out! Now I gotta yank the head n cylnder get it out...
Old 02-10-2012, 11:23 AM   #8 (permalink)
agdempsey's Avatar
Member #15733
At least you can pull head and cyl on bike. Easy to work on from what I remember back in the mid 70's.
Old 02-10-2012, 02:08 PM   #9 (permalink)
Member #8799
yeah pretty easy pull the head off cylnder n pistion fine, but somone had put this good size piece foam and its all tangled in the exhaust/intake valves! the dang valve compressor i have is too big... wonder if i can buy a chinese replacement head and slap it on? this head seen better days for sure!
Old 02-10-2012, 02:18 PM   #10 (permalink)
Member #7607
View Manny's Photo Gallery(0)
dont buy a chinese head, they wont last. buy the OEM from ebay. there are MANY parts on there. even if your getting spark. i suggest filing the points and cleaning them up. more than likely they need to be cleaned, i wouldnt be surprised if it gave you a stronger spark.
2001 Rubicon 500 5k+ miles 1100+hours
26 Inch Mudlite XL's, G Force Slammer wheels, Superwinch Terra
Realtree AP Plastics
Warn 2000 Lb. winch
Sedona Ripsaw tires
Fourtrax 300 Parts for sale CLICK HERE
The truth about ATV oil:
http://www.dirtrider.net/forums3/tex.../146867-1.html
coil honda ct70
ct70 forum
ct70 no compreasion
ct70 no spark
honda ct 70 forum
honda ct70 forum
honda ct70 forums
honda ct70 low compression
honda ct70 no spark
honda ct70 repair forum
honda ct70 valve adjustment tool
honda trail 70 compression
honda trail 70 no spark
how much is a 1972 ct70 trail bike going for
how to check compression in a honda ct70 motorcycle
how to date honda trail 70
points & cond for honda 70 trail parts
removing the coil from a honda trail 70
replacement carburetor for 1972 honda trail 70
trail 55 no spark
