Old 02-09-2012, 10:17 PM   #1 (permalink)
cjmcclelland's Avatar
Member #16027
View cjmcclelland's Photo Gallery(0)
quick pilot screw question
came across an 86 250 es big red, been sitting in a field for 10 or so years....got it running, but still has issues
schematics on pilot screw show oring,washer,spring, pilot screw...dont remember a washer coming out when i started rebuild..anyway..does oring go in first, then washer, then spring?..that would make sense to me, but I'm a newb......
cjmcclelland is offline   Reply With Quote
Old 02-09-2012, 10:33 PM   #2 (permalink)
Welcome to the forums. Slide the spring on the pilot screw, then the washer and the o-ring goes on last, next to the tip of the pilot screw.
Old 02-09-2012, 10:36 PM   #3 (permalink)
The o-ring, washer, and spring go on just like shown in this illustration.
Old 02-09-2012, 10:39 PM   #4 (permalink)
Member #16027
thanks...thats how i had it...finally did something right!
This thing would be alot easier to work on if i could use a sawzall.........
Old 02-09-2012, 11:01 PM   #5 (permalink)
You're welcome.
Old 04-16-2012, 09:21 PM   #6 (permalink)
Archer870's Avatar
Member #15663
View Archer870's Photo Gallery(0)
This is why I use the search feature.Was having trouble with Idle on my 1993 trx 300 and I just found out why.
Pilot screw assembly is wrong.I will have to see if washer is stuck in hole or have to order a kit.Thanks Helmut for the diagram,
it was exactly what I needed.This is the best forum I have ever been a part of. All of you guys are a Godsend,Thanks for all the
redundant questions of ours that you answer.
Democracy is two wolves and a sheep discussing what to have for dinner,Liberty is a well armed lamb contesting the vote.
2002 Foreman 450es 4x4
26" Pirelli Mudwiser tires
3000lb. winch
Archer870 is offline   Reply With Quote
Old 04-16-2012, 09:25 PM   #7 (permalink)
falconblack's Avatar
Member #10220
View falconblack's Photo Gallery(0)
Welcome home CJ
falconblack is offline   Reply With Quote
Old 04-16-2012, 09:32 PM   #8 (permalink)
You're welcome.
Old 04-25-2012, 09:59 PM   #9 (permalink)
dannyboy's Avatar
Member #17982
View dannyboy's Photo Gallery(0)
AMEN! I've searched and been a member of some other forums but got no answers as quickly (and turned out to be accurate) as I have here.
I add my thanks also.
dannyboy is offline   Reply With Quote
atv pilot screw spring
fix pilot screw spring
honda big red pilot screw
honda pilot atv forum
pilot screw honda atv
pilot screw o ring does
pilot screw washer honda
