Old 02-08-2012, 08:45 AM   #1 (permalink)
tomlbby's Avatar
Member #15983
View tomlbby's Photo Gallery(0)
i recently aquired a honda four wheeler,i beleive it between 89 to 96.has full time 4x4,decompression lever,front rear racks,metal tank etc.runs like a champ but i am hearing a like binding,squeak when i turn sharp corners even at low speed.Someone has welded the outer axle nuts on the rear axles(can still remove wheels) so i cant slide the brake drum cover back far enough to get to the brakes to check them.any suggestions.also it is shaft drive model,
cant seem to find a repair manual for it either.
also where can i get a repair manual download from?i tried through this site but wouldnt work.
tomlbby is offline   Reply With Quote
Old 02-08-2012, 09:05 AM   #2 (permalink)
DR_
DR_'s Avatar
Member #5369
View DR_'s Photo Gallery(0)
It is the rear differential going bad. If you can't get the axle nuts off you will not be able to fix and your only option will be replace the differential, axle, rear brakes, swingarm, etc.
DR_ is offline   Reply With Quote
Old 02-08-2012, 09:13 AM   #3 (permalink)
DR_
DR_'s Avatar
Member #5369
Link to manual [1995-2000]Honda_TRX300_TRX300FW_Fourtrax_Service_Repair_Manu al.pdfand use hondaatvforums.net as the password
One think you could do is cut the axle off that way you pull it out of the differential.
Old 02-08-2012, 09:17 AM   #4 (permalink)
tomlbby's Avatar
Member #15983
I tried the link to the manuals and it did not work.could download but even after download would let me open.
Old 02-08-2012, 09:56 AM   #5 (permalink)
rebelboy22jd's Avatar
Member #13474
View rebelboy22jd's Photo Gallery(0)
You are going to have to find a way to break the welds loose, or replace the whole rear end and everything. Sounds like the breaks, or the rear diff to me
2004 Honda Recon es --- front basket rack
1986 Honda Fourtrax 250 --- Uni Air filter, Supertrapp IDS2, 12'' ITP type 4's with 26-12-12 ITP 589's, 2in front lift, Snorkeled, custom exhaust snorkel
1997 Kawasaki bayou 220 --- project
1992 Yamaha Big Bear 350 4x4 --- 2in front lift, stick stoppers,
1979 Honda Atc 110 --- hardest thing to make run I have ever seen
http://www.youtube.com/user/rebelboy22jd?feature=mhee
rebelboy22jd is online now   Reply With Quote
Old 02-08-2012, 12:06 PM   #6 (permalink)
tomlbby's Avatar
Member #15983
Thanks,I just loosened the inner axle nuts,moved them back out of the way on the axle shaft toward wheel,slid the brake hub cover out as far as i could.i was not able to get the brake drum to slide back(frozen or something)on the axle shaft(tricks to try??).I disconected the rear brake cables and worked the brake actuator rod back and forths.I then put everything back together except for hooking up the rear brake cables.Took it for a test ride and heard no noises.Im thinking the brake shoes are gone or hanging up but i cant get the drum to move so i can replace them or see whats up.guess i will just run it for now with front brakes.
Old 02-08-2012, 12:07 PM   #7 (permalink)
DR_
DR_'s Avatar
Member #5369
Sounds like you need to reinstall Acrobat reader.
Old 02-08-2012, 12:56 PM   #8 (permalink)
try looking at your front brakes as well ?. as for your rear axle nut on the brake side being welded ?..this has to be one of the stupidest things i've ever seen !!!..i don't know why people think this will solve a problem !!..it only temp fixes it...when it comes time to replace the rear brake shoes ?..it's a royal pain to go through this chit !!!..lol. you need to get that welded crap off of it..and repair the atv the right way !!!..when it comes time to replace all the bearings and seals ?..your gonna hate it !..seeing how you can't get to the bearings and seals right now !..lol. while your looking at your front brakes ( have the atv up off the ground ..all 4 tires up ! )..take a look at your front cv-joints ?..if they clack ?..pop ?..when your turning ?..then they need servicing ?..or replaced ?. main thing right now ?..is get that stupid welding crap off the rear end !!..fix it the right way !.
Old 02-08-2012, 01:01 PM   #9 (permalink)
tomlbby's Avatar
Member #15983
i hear ya
Only way i can see doing away with the welded axles is to,cut them dissasemble the rears and install new axles.
Old 02-08-2012, 01:03 PM   #10 (permalink)
tomlbby's Avatar
Member #15983
i may have room to slide the drum out to the wheel and replace the shoes that way but i cant get the drum to move
1997 honda fourtrax 300 4x4 rear bearings install
1999 honda fourtrax 300 4x4
1999 honda fourtrax 300 complete rear end
1999 honda fourtrax 300 rear drive shaft
300 fourwheeler fourtrax
changing rear bearings 96 honda fourtrax 300 4x4
honda 300 atv forum repair diff
honda 300 fourtrax rear end
honda atv fourtrax 300 front brake seal
honda fourtrax noise after replacing swingarm bearings
how to change seals and bearing in read end of 1992 honda 300 4x4 atv
how to install rear end bearings in a 1997 honda fourtrax
how to put a rear end on a 2000 honda 300 fourtrax 4x4 back together
how to replace axle and bearings on a rear end of 2000 honda fourtrax 300 4x4 atv
lower cv joint four wheeler how to remove honda
rear brakes on 96 honda 300 fourtrax
rear end for 300 honda atv
replacing cv joint on 96 fourtrax 4x4
used four wheeler rear ends for honda fourtrax
