Old 02-07-2012, 10:24 AM   #1 (permalink)
MurdaShow's Avatar
Member #11177
View MurdaShow's Photo Gallery(0)
2004 Foreman 450 S Won't start.
I just bought a Foreman 450S 04'. It wont start/run. I've tried spraying starting fluid in the Carb, but it will only backfire occasionally. It has a new spark plug, The wire shocked the **** outa me when trying to crank it once, so im assuming it has spark. The motor has good compression.
The guy i bought it from said he changed the pulse module, in the motor? Also something was plugged in the wrong connector, and would not shift into neutral, but that problem has been fixed, just didnt know if it could cause anything else to malfunction.
Im guessing it could be a bad CDI or Regulator? How do i test these and is there anything else it could be? I plan on pulling a regulator off a rancher, (if it fits) and see if it will start.
MurdaShow is offline   Reply With Quote
Old 02-07-2012, 11:43 AM   #2 (permalink)
seeing how it shocked the crap outta ya !!!..lmfaooooo ( news flash..they bite ! )..lmfaooo..it's not a elec issue..this is not a fuel issue either..or it would have half way started on starting fluid..soooooooo..this leaves the last thing..it's a engine problem...bad ring's ?..no compression ?.bent or broken valve ?..timing is off ?..don't worry about your fuel or elec..it's not that..spec if you know it's getting fire at the plug....and you found that out the hard way !..lmfaooo.
Old 02-07-2012, 11:54 AM   #3 (permalink)
start by setting the timing marks on the flywheel....remove the sight cap...remove the rcoil starter..if your bike has one ?..if not..you need to get to the crank's 17mm bolt..so you can rotate the crank..remove the spark plug..rotate the crank until the T mark lines up with the index in the sight hole. remove the rocker box cover..yes..you will need to remove the fuel tank..and plastic shield under it to get to the rocker box..with the valve cover off..T mark lined up..feal your valves ..they loose ?..tight ?..with feeler gauges ( i don't use them..and i don't know what the spec's are for your bike ? )..set your valves. now take a comression gauge..with the kill switch off..spark plug laying on the engine somewhere...open the throttle wide open..crank it over for a few sec's..whats the reading on your compression gauge ? i do not know what the spec's are for your motor ?..butttt..i can tell you...you need at least 100 psi min to start an engine..this does not mean you can ride it like this..it only means the engine will run...soooo..if it's at or below 100 psi ?..then your compression is too low !..bad rings ?..bent valve ?.
Old 02-07-2012, 12:31 PM   #4 (permalink)
Member #7607
View Manny's Photo Gallery(0)
i agree with you shade, if it didnt fire with starting fluid, i would bet your bike has jumped time and bent a valve.
intake and exhaust valve clearance are .006
2001 Rubicon 500 5k+ miles 1100+hours
26 Inch Mudlite XL's, G Force Slammer wheels, Superwinch Terra
Realtree AP Plastics
Warn 2000 Lb. winch
Sedona Ripsaw tires
Fourtrax 300 Parts for sale CLICK HERE
The truth about ATV oil:
http://www.dirtrider.net/forums3/tex.../146867-1.html
Old 02-07-2012, 12:51 PM   #5 (permalink)
thanks manny for the spec's !..i don't know much when it comes to spec's...lol..as you know..i don't use or go by them..i go by feal..lol.
Old 02-07-2012, 02:40 PM   #6 (permalink)
Welcome to the forums. I agree with Shade and Manny. First step would be to check your compression. I'm guessing it jumped time and/or bent a valve.
Old 02-07-2012, 06:11 PM   #7 (permalink)
MurdaShow's Avatar
Member #11177
I had some people look at it, and work on it.. They think it jumped time.
Is it hard to fix?
Old 02-07-2012, 06:25 PM   #8 (permalink)
Is it hard to fix?
for you ?..or them ?..lol. as for me..no..but to someone that has never worked on one ?..then it's not that easy..at least not at first !..do you want to do it ?..or you gonna let them do it ?..can it be done at home ?..yes !..can you do it ?..only you will know !..with some basic hand tools..and a service manaul..it can be done.
Old 02-07-2012, 06:46 PM   #9 (permalink)
Member #7607
if i were you i would tear into it myself...nothing better then the sense of accomplishment after tackling a tuff repair.
Warn 2000 Lb. winch
Sedona Ripsaw tires
Old 02-07-2012, 06:53 PM   #10 (permalink)
i agree with manny..not to mention...look at all that beer money your gonna save !!!..then you can pass it on to me !..lmfao.
2004 450 honda foreman es why won't this model fire ?
2004 honda 450 foreman wont start
2004 honda foreman 450 es oil filter
2004 honda foreman 450 starts but wont run
2004 honda foreman 450 wont start
2004 honda foreman 450s sparkplug
450 foreman s wont run
99 honda foreman 450 s starts
centrifugal clutch gets hot
compression problem in 2004 honda foreman 450s
honda foreman 450 how to check oil pressure
honda foreman 450 intake exhaust valves
honda foreman 450 no start
honda foreman 450 wont start or go into 4x4
honda foreman won't start
how do you install a starter on a honda and foreman atv
how much is a honda foreman 450 timeing chain?
is there supposed to be slack in the cv axle on a honda 650 rincon
timing chain for 2004 honda foreman
why does 450 foreman won't start
