02-05-2012, 07:06 PM
#1 (permalink)
Member #12004
oil on the 300 engine?
Thought the oily engine was a gasket leak like the last one. Just finished reworking the rear axle and was going to take a ride after changing the oil.
Pulled the plug and knew I had problems. As the pics tell some people shouldn't own tools,nothing like an oversize coarse threaded bolt forced into cast aluminum.
Best way to weld up?
grind down flat and weld a fine thread aluminum nut on it to match oil nut.
put nut in hole and built up with aluminum around it,then tap oil to oil plug threads?
02-05-2012, 07:33 PM
#2 (permalink)
man..that has to be one of the worst bolt holes i've ever seen !..i'm not sure cast aluminum can even be welded ??.
02-05-2012, 07:49 PM
#3 (permalink)
Member #12004
Brother in law has a tig welder with argon/ aluminum spool gun to do it. Just did a cast head with it not pretty but it is solid.
02-05-2012, 11:58 PM
#4 (permalink)
Member #7607
it can be tig welded. i would go with the route you suggested. its definitely worth a shot. just make sure nothing broke off in the crankcase.
also, when you retap the hole, make sure to use plenty of cutting oil. (to keep the shavings out of the engine.) and if you can, dont tap it with the bike on its ass end. get underneath and tap it. (i've done this twice)
after your done flush with diesel and you'll be good as new. (this happens alot with the local farmers putting a bull hunch on all their drain plugs!)
02-10-2012, 11:38 PM
#5 (permalink)
Member #12004
OK,
Did the welding and built up the cracked area then ground it down and threaded hole. Filled it with diesel to flush out any particles,but it dripped around repair area.Put in a larger plug and rubber plug ring,still drips. Apparently air holes/fine seams in aluminum didn't get sealed good enough.
I just roughed up and coated entire area around weld with liquid JB weld to seal the fine holes,will this hold up on an atv bottom casting with oil and heat exposure and no stress pressure?
02-11-2012, 12:14 AM
#6 (permalink)
OK,
i honestly don't think it will hold..jb weld is not what it used to be !.
02-11-2012, 12:23 AM
#7 (permalink)
Member #12004
Any suggestions as its hard to tell where it is seeping from? Maybe if I go over the JB with seals all and then paint it all with engine enamel to keep it in place?
doesn't seem like it would have much more vibration than a sealed gas tank would.
I have another good housing,just don't feel like tearing down engine right now,as it runs fine,figured on doing that down the road when it needs a rebuild.
02-11-2012, 07:27 AM
#8 (permalink)
Member #11269
I'd keep an eye on it, as long as it only drips a drop or two on the ground every day I'd just watch the oil level and ride.... unless you feel like breaking out the welder again.
Kawasaki prairie 400ish stockish
1995 honda fourtrax 4x4, stock.
02-11-2012, 08:38 AM
#9 (permalink)
Member #8144
Maybe you could take the tig torch and reheat it and maybe it could get some of the air pockets out??
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
02-11-2012, 10:04 AM
#10 (permalink)
Member #11544
Clean it real good and try Mono caulking, auto shops use it on transmission pans believe it or not.
2011 Honda TRX420 PG CTE camo
Atuo & Electric Shift -- IRS -- Programmed Fuel Injection
25" Kenda Bear Claws
2500 Runva Winch
Thumb & Hand Warmers
400ex oil drain bolt, atv honda enginerepairhonda atv forum, best way to flush out atv engine, can you weld an aluminum nut to fix oil plug on honda 420, good honda atv oil, honda atv oil drain plug cracked casting, honda fourtrax oil plug, welding crack threaded hole oily threaded cast aluminum tig
