1985 250ES Big Red Exciter coil - Honda ATV Forum
Old 01-29-2012, 07:42 PM   #1 (permalink)
dougharr's Avatar
Member #15762
View dougharr's Photo Gallery(0)
I have a 1985 250ES Big Red that after it has been running for about 10-15 minutes just quits. I believe that the problem is the exciter coil since the resistance between the blk/red wire to ground goes from 360 ohms when it is cold to over 500 ohms when it quits. After about 5 minutes after it cools down the resistance for the exciter coil goes back down to 360 ohms then it starts. According to the service manual the blk/red wire to ground should read 50-200 ohms. My question is where is the exciter coil located?? Is it part of the alternator??
Any help would be appreciated. Thank you in advance.
dougharr is offline   Reply With Quote
Old 01-29-2012, 07:54 PM   #2 (permalink)
Welcome to the forums. Yes, it's one of the coils on the stator/alternator assembly.
1985 big red coil
1985 honda 250 big red manual
1985 honda atc 110 exciter coil
1985 honda big red 250es free repair manual
1985 honda big red coil
1985 honda big red runs but quits after a while
exciter coil honda
exciter coil honda 250es
exciter coil resistance
honda exciter coil
what does an exciter coil do
what does an exciter coil do on a honda 200
