450 es Angle sensor question....I know I know - Honda ATV Forum
Old 01-19-2012, 08:38 PM   #1 (permalink)
Snotrod's Avatar
Member #12192
View Snotrod's Photo Gallery(0)
I know this one has been done to death and I have fixed these before but this one has me scratching my head. My buddy is is having issues with his ES not shifting so I told him to replace the angle sensor after inspecting a few things myself. So he did and it worked for a bit then he had the same problem only worse. With the original sensor it will shift into first and reverse. With the new sensor it will now only shift into reverse and what seems to be half way into first then it pops back to neutral.It is throwing the 3 blink code for ES problems. We have tested the wiring , the battery is at 12.84 volts or something like that and we have checked all of the fuses. He also bought a new shift motor thinking that may be the problem. I now think the new angle sensor that he bought is toast. Any ideas /input would be great. Thanks
Snotrod is offline   Reply With Quote
Old 01-19-2012, 09:36 PM   #2 (permalink)
Have you tried adjusting the clutch free play to see if it will help?
Old 01-20-2012, 06:52 AM   #3 (permalink)
Snotrod's Avatar
Member #12192
I adjusted the clutch last night because I noticed it was jumping forward when we shifted it into 1st. There wasn't much improvement after adjusting it...if any. Aside from plowing snow this machine hasn't been used hard. Helmut thanks for the reply. Any other ideas??
Old 01-20-2012, 04:52 PM   #4 (permalink)
Have you followed the troubleshooting chart in the service manual, for code 3?
Old 01-20-2012, 07:45 PM   #5 (permalink)
Snotrod's Avatar
Member #12192
I went through most of it last night. I still have to check the voltage. Kind of ran out of time..had to get the kiddies to bed.
Old 03-24-2012, 09:27 PM   #6 (permalink)
Snotrod's Avatar
Member #12192
FYI this turned out to be a broken bolt in the trans. Haven't posted here in while just thought I'd give an update. Maybe this will help someone in the future.
Old 03-24-2012, 11:54 PM   #7 (permalink)
Member #7607
View Manny's Photo Gallery(0)
Liked: 160 times
Broken bolt? can you be more specific as to where? this intrigues me as to why it wouldnt shift.
HONDA parts for sale
1998 honda 450 e s atv
1998 honda 450 es atv
1998 honda 450es angle sensor
450 es angle sensor
honda 450 angle sensor
honda 450 es angle sensor
honda angle sensor
honda angle sensor problem
honda atv angle sensor
how to fix angle sensor on honda 450es
what does an angle sensor look like on an atv
