no oil to topend of rubicon - Honda ATV Forum
Old 01-13-2012, 02:19 PM   #1 (permalink)
houser450's Avatar
Member #15400
View houser450's Photo Gallery(0)
Ive got a 2005 rubicon and it is not getting oil to the topend. First of all hondamatic seemed to be working how it should be, no noise or anything odd so i must have oil pressure. now ive got engine out and tore back cover off. i traced the oil line pretty much to the subtrans and seems to be clear to that point where does the oil come from before that point any help would be great thanks in advance
houser450 is offline   Reply With Quote
Old 01-13-2012, 02:32 PM   #2 (permalink)
Member #7607
View Manny's Photo Gallery(0)
Liked: 161 times
did you have an oil pressure test done? i wouldnt rule that out just by "assuming" that it was working properly
HONDA parts for sale
Old 01-13-2012, 02:55 PM   #3 (permalink)
vermhot's Avatar
Member #14174
View vermhot's Photo Gallery(0)
Send a message via Yahoo to vermhot
welcome dude !!! x2 on the oil press check first !!!!
05 Green Foreman
DGL,2"SS-Lift
Plano green hunting box
11 Green Rubicon
Gscape,power steer
crappy stock tiers
Kolpin hitch
http://youtu.be/i9MhWDPUDHo
vermhot is offline   Reply With Quote
Old 01-13-2012, 03:27 PM   #4 (permalink)
Welcome to the forums. Looks like the oil runs up around one of the cylinder/head bolts to the top of the engine. If anyone has ever taken the head or cylinder off, they may have used some type of sealant on the gaskets and it may have stopped the hole up where it comes up around the outside of the cylinder stud.
Old 01-14-2012, 08:02 AM   #5 (permalink)
56S
56S's Avatar
Member #14940
View 56S's Photo Gallery(0)
I agree with Helmut here. Many Hondas had flow restrictors installed as alignment pins between the head and cylinders. These looked like the standard knock pin but had a small hole with a dia. of .010-.015" (WAG system of measument). Over use of silicone sealer has ruined many a top end.
56S is offline   Reply With Quote
Old 01-14-2012, 10:45 AM   #6 (permalink)
bobs330's Avatar
Member #8144
Was an oil change done recently? Maybe oil filter was accidently installed backwards??
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
Old 01-17-2012, 10:11 AM   #7 (permalink)
houser450's Avatar
Member #15400
thanks guys i think i found a blockage in the tiny hole in the subtrans shaft that feeds the back engine cover which then feeds the topend cleaned it out gonna give it a try. and by the way im almost positive that someone was in there before and they used way to much hondabond had to clean both pickup screens out and some misc pieces just laying around
Old 01-17-2012, 10:41 AM   #8 (permalink)
Liked: 1385 times
coulda been done from the factory ?..most ppl don't know or use hondabond..they use rtv sealant !..now...honda uses the hondabond..this i know !..it may have been done from the factory !!!. who knows ??. hope it works out for ya !.
Old 01-30-2012, 01:12 PM   #9 (permalink)
houser450's Avatar
Member #15400
still no oil to top
well put the thing back together and didnt solve the problem so gonna have to check the oil pressure next does anyone know where i can get a 10by 1.25 fitting to screw into the engine. i found a guage just need the adapter fitting. thanks again guys.
Old 01-30-2012, 08:25 PM   #10 (permalink)
mdec950's Avatar
Member #13751
View mdec950's Photo Gallery(0)
I bet Helmut used too much honda bond or gasket maker at one time and learned this one the hard way!!1
Rules for HondaATVforums.net
If you can't figure it out,
rule 1 - drink a beer,
rule 2 - see rule 1 - rinse and repeat
rule 3 - calm down and let it sit - leave it alone
rule 4 - get on here and ask Helmut or Shadetree
rule 5 - and be nice when you ask.
rule 6 - go and
mdec950 is offline   Reply With Quote
01 rubicon oil pressure check
07 honda foreman 500 head bolt stud by the oil galley
450 honda foreman no oil pressure
honda at oil not getting top end
honda foreman oil clogged
honda rubicon no oil
honda rubicon oil pressure
honda rubicon oil pressure check
oil presssure top end honda rubicon
rubicon no oil pressure top end
too much honda bond
why does atv get no oil to top end
