12-05-2011, 09:35 PM
#1 (permalink)
Member #13274
Got the carb working after a stupid move
I rebuilt my carb on my 1992 Honda TRX300FW. i followed the instructions that are sticky in the repair/maintenance forum. When i out the carb back on the bike and set the petcock to on/reserve, fuel starts to pour out the tube on the bottom of the carb. What did i do wrong? any suggestions?
12-05-2011, 09:37 PM
#2 (permalink)
Member #11909
could be the float needle not seating correctly or a hole in the float
2004 400ex
yoshimura slip on
uni filter
426 kit
moose bars
dg bumper
msr clutch
itp c-series rims
#3 (permalink)
Member #14174
Needs rebuild !!!
05 Green Foreman
DGL,2"SS-Lift
Plano green hunting box
11 Green Rubicon
Gscape,power steer
crappy stock tiers
Kolpin hitch
http://youtu.be/i9MhWDPUDHo
12-05-2011, 09:44 PM
#4 (permalink)
Member #805
Did you forget to put the needle valve back in
12-05-2011, 09:45 PM
#5 (permalink)
Member #13274
the float is fine. i put it under water to see if there were leaks. also the float needle it setting correctly because i took apart the carb over and over again to try and see if it was getting stuck and it seems fine. I used the new float needle and also the old one and it does the same thing. when fuel comes out the tube on the bottom of the carb, does it mean that the fuel bowl if full, and if so, were does the fuel enter that tube?
12-05-2011, 09:48 PM
#6 (permalink)
Member #13274
Originally Posted by vermhot
Needs rebuild !!!
i just did.
12-05-2011, 09:52 PM
#7 (permalink)
Member #805
Did you set the float level? When the bowl over fills it bleeds out a hole above the fuel level in the bowl, sounds like the float level is to high, your funny pages should show you how to adjust
12-05-2011, 09:54 PM
#8 (permalink)
Member #7607
i dont believe the float is adjustable on the fourtrax. could very well be wrong....turn the gas off, tap the bowl with a small hammer. that may be able to free up the float and wont leak
Realtree AP Plastics
Warn 2000 Lb. winch
Sedona Ripsaw tires
2013 Can Am Commander 800 XT
Roof, F&R Windshield's, 27 inch bighorn's
*Download your FREE service manual BELOW*
12-05-2011, 09:55 PM
#9 (permalink)
Member #4493
Yep fuel comming out the overflow tube means the bowl is full and the float needle is not sealing. When you rebuilt the carb did you use compressed air to blow out all the passages? Sounds like you may have some trash still in the seat passage.
2004 Rincon
2" lift
27" mudlites, ITP SS212's
Mud bike
2004 Rancher 400AT
Bone stock
Hunting and trail bike.
12-06-2011, 05:21 AM
#10 (permalink)
Member #11269
Is it coming out of the overflow or the carb drain screw? Is it possible you over looked crud in the drain screw passage and its leaking past? Wouldn't be the first time they started leaking on me after a cleaning...
98 honda four trax leaking gas from the overflow, why, fuel is pouring out bottom of carb on honda 300 fourtrax, gas spilling out of bottom of dirtbike, honda foreman 500 carburetor overflow valve picture, honda foreman rubicon 500 leaking fuel, honda forman rubicon leaking gas from sm tube off carb, honda fourtrax leaking gas out overflow, honda fourtrax overflow tube, how to fix open float on atv leaking gas, rancher carb leaking from overflow tube, rancher leaking gas from drain tube, what does it mean when gas comes out of the carburetor
