stalling rubicon 500 - Honda ATV Forum
post #1 of 11 (permalink) Old 11-27-2011, 11:03 AM Thread Starter
bigtruckatley's Avatar
Question stalling rubicon 500
I have a 2001 rubicon 500, I have gone through entire fuel system and carb and everything is clean. It idols fine till you try to accelerate, then it chuggs and stalls. restarts no problem. Help!!! any sugestions????
bigtruckatley is offline
post #2 of 11 (permalink) Old 11-27-2011, 11:32 AM
falconblack's Avatar
Did you pull plug out to see if it was flooding?Next loosen gas cap to see if it is vapor locked caused by pluggeg cas cap vent hole.
falconblack is offline
post #3 of 11 (permalink) Old 11-27-2011, 11:38 AM Thread Starter
Thanks for replying, I have and plug is ok, I have taken carb apart, jets are ok, same with the floats. I think its something deeper, maybe electrical. Was hoping someone might have a direction to look into further
post #4 of 11 (permalink) Old 11-27-2011, 11:39 AM
Try gas cap then new plug!!
post #5 of 11 (permalink) Old 11-27-2011, 11:40 AM Thread Starter
Thanks, I will check that. Any other suggestions?
post #6 of 11 (permalink) Old 11-27-2011, 11:42 AM
I usually do one step at a time then worry about worse things.
post #7 of 11 (permalink) Old 11-27-2011, 11:42 AM
submarine 300's Avatar
Does it die when on flat ground or on an incline?
submarine 300 is offline
post #8 of 11 (permalink) Old 11-27-2011, 11:46 AM Thread Starter
It dies on both, but it is definelty worse on an incline. But, it starts right back up no problem. It gets worse the longer it runs as well
post #9 of 11 (permalink) Old 11-27-2011, 11:57 AM
jake72's Avatar
might need to rebuild the carb
jake72 is offline
post #10 of 11 (permalink) Old 11-27-2011, 12:08 PM
Since it's worse on an incline it makes me think it's a fuel problem. Have you pulled the supply line to the carb to see if there is a good flow of gas?
