2004 TRX400FA Fourtrax/Rancher - Honda ATV Forum
Old 12-20-2009, 01:32 PM   #1 (permalink)
Daemonw's Avatar
Member #1408
View Daemonw's Photo Gallery(0)
Unhappy 2004 TRX400FA Fourtrax/Rancher
Thought I'd start a new thread of my own, just for the specific problems with the Honda ATV's which appear to be prevalant.
1. Code 6 - angle sensor. Many issues with these, replaced mine, problem is gone.
2. Code 12 - shift control motor (or circuit). I replaced the shift control motor, which after reading many forums, I understand a LOT of people do this as well and still have problems. Me too! Big surprise.
3. 4X4 is flashing 4 times, which indicates system voltage issue apparently? Has anyone had any encounters with this one?
Did I seriously pickup the biggest POS Honda in the world? After much reading online, I thought I was getting into one of the toughest and longest lasting ATV's in in the market.
I've di-greased most of the connections on the machine, and didn't see any obvious signs of corrosion.
I'm still blowing the 30amp shift control motor fuse, which leads me to believe there is some form of wiring issue, likely shorting to ground?
Does anyone have any recommendations or ideas?
When I start the machine, it goes right to the error codes, and I cannot drive it other than in limp mode. BRUTAL!!! Getting so frustrated with this thing.
Help, help, help, for the love of god ....
Daemonw is offline   Reply With Quote
Old 12-20-2009, 01:42 PM   #2 (permalink)
mud99's Avatar
Member #988
View mud99's Photo Gallery(0)
I would start with the wires running to the fuse. Trace the wires to see if you can find were the short is.
My Rides
2002 F-250 4x4
250R
www.trxforums.com
mud99 is offline   Reply With Quote
Old 12-20-2009, 01:50 PM   #3 (permalink)
tomgodd's Avatar
Member #126
View tomgodd's Photo Gallery(0)
I agree with mudd99.
NEVER TAKE A SLEEPING PILL AND A LAXATIVE IN THE SAME NIGHT!
http://www.youtube.com/watch?v=Exbsw5ssn4I
Equal opportunity offender.
tomgodd is offline   Reply With Quote
Old 12-20-2009, 03:01 PM   #4 (permalink)
Saber6's Avatar
Member #193
View Saber6's Photo Gallery(0)
Liked: 5 times
Seems that I remember reading about faulty ecms and the dealers were picking up the tab. Cant be sure with out contacting the dealer tho. With 4x4 light flashing my guess is an ecm issue but thats just a guess.
http://www.oilburners.net/forums/cus...atar1326_2.gif
BOOB man - "Brotherhood of Oil Burners" Local 715
Sometimes I wonder,.."Why is that Frisbee getting bigger,..? then it hits me,...
Saber6 is offline   Reply With Quote
Old 12-20-2009, 04:59 PM   #5 (permalink)
Member #417
Liked: 304 times
I agree with Saber and mud check the wiring first if you don't find anything then check into what saber was telling you.
Old 12-20-2009, 07:17 PM   #6 (permalink)
Daemonw's Avatar
Member #1408
Hey guys - props for supporting a guy in need ! LOL. Really though, it's great that you support those with issues and less product knowledge than yourselves.
I used a multi-meter and traced the wires back per the troubleshooting schematic. Battery to ECM, ECM to the shift control motor, etc. I picked-up solid signal and the appropriate voltage to the ECM from the battery.
Could I really be the guy with a bad ECM? I've read dozens of forums where guys do all I have done (angle sensor, shift control motor, and ECM) and STILL have a dead ATV.
I found a line on a NOS (new old stock) ECM for around $100 shipped, which compared to the local dealer cost is a steal of a deal. I'm thinking of getting it just in case it is the ECM. I need to start plowing my driveway very soon, so I'm worried I'll be stuck without a machine.
Any other thoughts, comments, etc. would be appreciated.
I'm still concerned as to why I keep blowing the 30amp shift control motor fuse. For some reason the system is drawing in excess of 30 amps, but throughout the wiring system related to the shift control motor, all checked out. Baffled in Ontario.....
Old 12-20-2009, 07:19 PM   #7 (permalink)
Daemonw's Avatar
Member #1408
Mind you I didn't check the wires going TO the fuse, just leading away from it through the shift control motor circuit. Shouldn't those wires come directly from a voltage regulator of some sort? Could this be why I'm having the 4X4 light flashing 4 times indicating a system voltage issue?
Thoughts/comments more than welcome!
Old 12-20-2009, 07:22 PM   #8 (permalink)
mud99's Avatar
Member #988
Just to be on the safe side I would check both sides.
My Rides
2002 F-250 4x4
250R
www.trxforums.com
Old 12-21-2009, 06:27 PM   #9 (permalink)
Daemonw's Avatar
Member #1408
I'll do that .....and I just ordered a new ECM.
So....IF I plug in the new ECM and go through the reinitialization process and the machine still gives me the error codes.....THEN WHAT?
I've read of this many times, and I'm scared that will be the result.
Fingers are crossed.....
Old 12-21-2009, 07:06 PM   #10 (permalink)
Saber6's Avatar
Member #193
Liked: 5 times
Found some info...
2004 honda rancher 400 fuse locations
2004 honda rancher error code 6
2004 honda trx400fa control motor
2004 trx400fa wiring diagram
battery running on a 2004 trx400fa
do i have to replace angler senser and ecm at the same time on trx400fa
honda 2004 trx400fa rancher angle sensor
honda trx 400 fa service manual free download
honda trx400 fa trouble shooting
owners manual for 2005 honda trx400fa
trx400fa angle sensor
trx400fa common causes of open circuits
