No fuel to spark plug - Honda ATV Forum
Old 10-18-2011, 07:43 AM   #1 (permalink)
JSFRIED's Avatar
Member #13626
View JSFRIED's Photo Gallery(0)
Hi all, i have a 87 fourtrax 4 wheel drive 350. My neighbor gave this atv to me after its been sitting for atleast 6 years. So i did the basics, clean old fuel out, cleaned tank, new spark plug, clean carb, install carb repair kit, and new battery. I had it running, would idol fine and run fine but full throttle would bog down, and had a tap/ ping. In the mean time it quit running. So i pulled the carb back off and cleaned again and decided to adjust valves while it was a part. Put everything back together wouldn't start. So i removed exhaust and it fired right up. Thought maybe exhaust was stuffed. So i cleaned exhaust and muffler put back on fired up but had to hold full throttle so it would stay running and no matter what i adjusted on carb didn't change anything, quit running now won't fire up. Pulled plug has no fuel at plug. Any suggestions. Also for side note this is electric start with kick back up, kick start works but after about a revolution it seems to lock up and can't kick but electric start still turns over motor.
JSFRIED is offline   Reply With Quote
Old 10-18-2011, 07:53 AM   #2 (permalink)
stu5969's Avatar
Member #8254
View stu5969's Photo Gallery(0)
Liked: 26 times
Will the machine keep running with the choke on at all times? That's a sign of a fuel flow problem still, such as a venting issue in your fuel cap, or your fuel valve on the tank itself is gummed up with some crap. Take your fuel line off on the carb end, and get yourself a catch can of some type and turn on the fuel valve and look for a good steady flow of fuel. The carb float height could be out of adjustment also, and not letting enough fuel into the bowl to keep the machine running, as well as looking through all the jets carefully and see if something is maybe not still lodged in one of the jets keeping fuel from coming though. I would also look for leaks on the intake manifold to the engine for cracks in it or leaks.
Thats a couple of good places to start to look, and let us know what it does from there.
stu5969 is offline   Reply With Quote
Old 10-18-2011, 08:07 AM   #3 (permalink)
JSFRIED's Avatar
Member #13626
I have good fuel at fuel line. I noticed when i try to fire and everything is hooked up i get air blowing out of drain at bottom of air filter box. So i removed that and intake tub and try to start with carb cleaner, every other revolution its sprays back out. I will check compression when i get home tonight, and also i still had a tap/ ping after i adjust valves.
Old 10-18-2011, 09:12 AM   #4 (permalink)
Dan G's Avatar
Member #11269
View Dan G's Photo Gallery(0)
Liked: 6 times
I don't think you adjusted the valves right, sounds like the intake valves aren't closing all the way, I'd do it again and make sure your at tdc on the compression stroke, and not mistaking mm's for standard measurement...
Old 10-18-2011, 09:17 AM   #5 (permalink)
Liked: 1534 times
you are correct !!!..OP..your timming is off..it's not set right ?..or it jumped time ?..like dan said..you musta set the timming on the ex stroke !..i hope you did not bend or break a valve ?. these old gals are a real pain to get the valves set just right. and welcome to the forums.
Old 10-18-2011, 09:21 AM   #6 (permalink)
Liked: 1534 times
the tap and ping you heard is your valves or timing chain !!!..probally both !..re-check your valves for your settings ??..i can tell you right now..your valves are set on the ex stroke..and not the compression stroke !!..lol. pray you did not bend or break a valve !.
Old 10-18-2011, 09:24 AM   #7 (permalink)
Liked: 1534 times
when you line up the T mark on the flywheel..just so you know your on the compression stroke..turn the flywheel the other way just alittle..as your doing this..watch your intake valves...if they start to move..then you had the T mark set for the compression stroke..just ease the flywheel back the other way back to the T mark where you had it..this is your TDC on the compression stroke. if you get stumped..holler at me..i'll walk you through it.
Old 10-18-2011, 09:25 AM   #8 (permalink)
Liked: 1534 times
and when you get alllllll that done..run a compression test on the bike..these old gal's require alottttt of compression to run right..they are not your normal atv !..lol.
Old 10-18-2011, 09:29 AM   #9 (permalink)
Liked: 1534 times
would like to add..the reason your not getting fuel to your spark plug..lol..is because your piston is not pulling fuel into the cylinder..because your motor's valves are not letting the piston create any suction to pulling the fuel in...this tells me your valves are set wrong.
Old 10-18-2011, 09:30 AM   #10 (permalink)
Liked: 1534 times
PLEASE DO NOT TRY RUNNING IT UNTIL YOU RECHECK YOUR VALVES !!!!!...parts for these ole gals are getting rare to find !.
fuel not getting to cylindar atv
fuel not getting to spark plugs
gas not getting to spark plug
no fuel getting to spark plug
no gas getting to spark plug
no gas on spark plug
no gas to spark plug
no gas to spark plug on 110 atv
no gas to spark plugs
no petrol reaching spark plugs
not getting fuel to spark plug
not getting gas to spark plug
