Remove Starter 1986 TRX350 Fourtrax - Honda ATV Forum
post #1 of 9 (permalink) Old 10-02-2011, 08:06 PM Thread Starter
molsen33's Avatar
I have removed several bolts in and around the starter, but I cannot remove the starter. Am I missing something??
Any advice would be appreciated.
Matt
molsen33 is offline
post #2 of 9 (permalink) Old 10-02-2011, 08:11 PM
arcticrider's Avatar
you have to take off the starter gear cover on the ouside of the engine case. slip of the stater gear and then wiggle the starter out from the other side. the starter is held in by only 2 bolts the starter motor shaft is being held in those gears and doesnt allow any wiggle room till you take the gear off
arcticrider is offline
post #3 of 9 (permalink) Old 10-02-2011, 08:17 PM
Liked: 24 times
Yep, like stated above, take the reduction gear cover off the left side of the engine and remove the reduction gear and this will allow you to tilt the end of the starter up and then the starter will pull out. And welcome to the forums.
post #4 of 9 (permalink) Old 10-03-2011, 04:46 AM Thread Starter
molsen33's Avatar
Thanks for the quick responses!
I spotted those 2 bolts last night. They seem to be a challenge to get to them, but I'm going to attack them tonight.
Thanks Again!
MAtt
molsen33 is offline
post #5 of 9 (permalink) Old 10-03-2011, 02:52 PM
Liked: 24 times
Yeah, just remove those two bolts, remove the reduction gear cover on the right side of the engine and pull out the reduction gear and then lift the end of the starter up and pull it out.
post #6 of 9 (permalink) Old 10-05-2011, 04:19 PM
SKULL's Avatar
This helped me on my starter ,new member skull ,,i was missing the cover to get out the starter ,,great site for all atv repaires
SKULL is offline
post #7 of 9 (permalink) Old 10-05-2011, 04:24 PM
Liked: 24 times
Welcome to the forums.
post #8 of 9 (permalink) Old 10-05-2011, 04:25 PM
Liked: 1793 times
as stated..starter cover off...middle reduction gear out..two bolts on end of starter..starter lifts out from back side. very easy to do...when you go to put it back together...DO NOT LEAVE THE SPACER WASHER OFF THE FRONT SIDE OF THE FLYWHEEL REDUCTION GEAR !.
post #9 of 9 (permalink) Old 10-05-2011, 04:26 PM
Liked: 1793 times
