front wheel bearing - Honda ATV Forum
Old 09-12-2011, 11:26 PM   #1 (permalink)
myersth's Avatar
Member #12851
View myersth's Photo Gallery(0)
front wheel bearing
found out left side bearings are going. still rolls nice but has free play any way u wiggle up down left right. how worried should i be and can any one tell me the size of the bearings
2003 Honda 300ex
k@N filter
FMF pip
jetted
2001 Honda 300ex
basicly stock
beat needs work
myersth is offline   Reply With Quote
Old 09-12-2011, 11:30 PM   #2 (permalink)
Liked: 1528 times
don't know the size..but you can look the bearings up on bikebandit.com, or ebay..just go to ebay..type in your make and model..and it will show you all kinds and prices of them.
Old 09-12-2011, 11:32 PM   #3 (permalink)
And I would replace the bearings as soon as possible. If you ride with them bad for too long, it can wallow out the hubs and the new bearings won't fit tight and if this happens, you will have to have new hubs.
Old 09-12-2011, 11:33 PM   #4 (permalink)
Liked: 1528 times
agreed^^^^^^!!!!
Old 09-13-2011, 10:10 PM   #5 (permalink)
myersth's Avatar
Member #12851
ok thanks guys. ill put that on the todo list. might not get fixed till late winter or spring but thats not my primary quad so its all good
2003 Honda 300ex
k@N filter
FMF pip
jetted
2001 Honda 300ex
basicly stock
beat needs work
Old 09-13-2011, 10:41 PM   #6 (permalink)
myersth's Avatar
Member #12851
alls so any tools i need for bearing removale? i replaced a stearing stem bearing with a hammer and peace of wood hitting it around the egdge will that work for these to
2003 Honda 300ex
k@N filter
FMF pip
jetted
2001 Honda 300ex
basicly stock
beat needs work
Old 09-13-2011, 11:45 PM   #7 (permalink)
Liked: 1528 times
unless they have a snap ring holding the bearings in the steering knuckle ??..just about anyway you can knock the old/new bearings in/out..will work..some knuckles..like on the trx300's..have snap rings under the dust seal..this keeps the bearing from comming out..soooo...make sure when you remove the dust seals..that you don't have..or didn't have any snap rings ?.
Old 09-13-2011, 11:50 PM   #8 (permalink)
myersth's Avatar
Member #12851
ok i got snap rings that aint a problems i was just worried bout the bearing its self because dont some u need to press in and i dont got a press. can the seals be reused if i dont mess them up?
2003 Honda 300ex
k@N filter
FMF pip
jetted
2001 Honda 300ex
basicly stock
beat needs work
Old 09-13-2011, 11:53 PM   #9 (permalink)
Liked: 1528 times
yes..if you do not mess up the seals ( and this is where bearing grease does wonders ! )..you can re-use them. as for not having a press..neither do i !..lol..a large socket..a good hammer...( brass hammer if you have one ? )..works great ..if you don't have a brass hammer..just use a large enough socket to hit the bearing fairly even and square !..you don't wanna get it going back in crooked !..make sure to grease not only the bearing..but also the steering knuckle where it goes in.
Old 09-13-2011, 11:54 PM   #10 (permalink)
Liked: 1528 times
and with new bearings..remove the inner bearing race ( plastic cover ).and re-pack them with more grease !!!!!..most do not come packed very well with grease from the factory !.
2003 300ex wheel bearing size
2003 honda 300ex
are the front wheel bearings on a honda 300ex pressed in?
atv bearing temp fix
change front wheel bearing on four wheeler 400 for man
does a 2003 honda trx350fe a have front bearings?
honda atv wheel bearings
how do you take a wheel bearing of a 4wheeler
how to get honda front bearing out
how to replace front wheel bearings on a honda 300ex
what happens if you don't change your front bearing in your four wheeler
what way do the bearings come out of my 300ex front wheel?
