2000 honda recon 250 carb probblems - Honda ATV Forum
Old 09-11-2011, 08:58 PM   #1 (permalink)
honda440exrider's Avatar
Member #1532
View honda440exrider's Photo Gallery(0)
well here goes. bought a 2000 honda recon. old guy said he used it for deer hunting. well who knows but going up a hill it cuts out and dies. like not getting enough fuel. pull choke when it starts to spuder and its fine to go up the hill. got into some mud today and it didnt like that very well either. it has 0 throttle response but i usually ride a 400ex help? bigger jet?
1999 honda 400ex bored 0.40over
new timing chain.
new pistion and rings.
valve job
450r carb
open airbox wk&n
nerf bars,
big gun full system pipe
itp wheels,
full belly skid plate
fox shocks
rear douglas beadlock rims
2005 450r
hmf slip on
durablue axle
axis rear shock
gt thunder front shocks
nerfs
dg front bumper.
blingstar sprocket and rotor guards.
hand guards.
full belly skid.
hyper rear rims looking for fronts.
honda440exrider is offline   Reply With Quote
Old 09-11-2011, 09:03 PM   #2 (permalink)
Carb probably needs to be taken off and cleaned.
Old 09-11-2011, 09:05 PM   #3 (permalink)
Member #1532
it has been cleaned last summer when we ran into this probblem. didnt help anything.
new timing chain.
valve job
450r carb
open airbox wk&n
nerf bars,
itp wheels,
fox shocks
2005 450r
hmf slip on
durablue axle
axis rear shock
nerfs
dg front bumper.
hand guards.
full belly skid.
Old 09-11-2011, 09:58 PM   #4 (permalink)
Not sure then, but it shouldn't need a bigger jet unless someone added a pipe and air filter or messed with the jets before. Pull the gas hose off the carb and make sure gas is flowing from the tank good. Also, check to make sure your gas cap vent isn't clogged. If putting the choke on, makes it pick back up and run good, then you're definitely not getting enough fuel for some reason.
Old 09-11-2011, 10:29 PM   #5 (permalink)
Liked: 1385 times
float sticking..bad gas from last season..dirty petcock filter....clogged jets..you can not leave a atv sit for very long without running it..in todays gasoline..ethenol kills just about every carb these days.
Old 09-12-2011, 04:13 PM   #6 (permalink)
Member #1532
if the float was sticking gas would pour out? and maybe clogged jets. its my brothers now. still doesnt ride it, usually sits around
new timing chain.
valve job
450r carb
open airbox wk&n
nerf bars,
itp wheels,
fox shocks
2005 450r
hmf slip on
durablue axle
axis rear shock
nerfs
dg front bumper.
hand guards.
full belly skid.
Old 09-12-2011, 07:30 PM   #7 (permalink)
Liked: 1385 times
a bad float will not only make it over flow..but also not get gas to fill up the float bowl like it should.
1999 honda recon fuel problems
2000 honda 250 recon carburator trouble shooting
2000 honda recon 250 carburetor
2000 honda recon 250 fuel filter
2000 honda recon bogs at full throttle
2000 honda recon carb
2000 honda recon carburato
2000 honda recon carburetor
fuelfiltergastank2000hondarecon250
honda 250 recon carburetor 2000
honda recon 250 carb rebuild
trouble shooting honda 1997 recon 250 replace carb. running full throttle
