2000 Foreman 450ES Swingarm Bearings - Honda ATV Forum
Old 09-11-2011, 08:15 PM   #1 (permalink)
jakedog's Avatar
Member #2234
View jakedog's Photo Gallery(0)
Hi -
What's the process to replace the bearings in the swingarm on a 2000 Foreman 450ES? Also, the boot over the u-joint has a crack in it. Do you have to remove the axle and differential to get at it?
Thanks
jakedog is offline   Reply With Quote
Old 09-11-2011, 08:39 PM   #2 (permalink)
You don't have to remove the axle and differential. Just jack up the ATV under the engine and remove the pivot bolts on each side of the frame that holds the swing arm on. Then, remove the whole swing arm, differential, and axle as an assembly. You can change the rubber u-joint boot while you have the swing arm off, since the drive shaft will come out with the swing arm.
If you don't have the service manual, go to the link below and download it and it will show you how to remove the swing arm. Look in the "Rear Wheel/Suspension" section under "Swing Arm". Just ignore the part about removing the axle and diff and just remove the brake cables, shock, and the swing arm pivot bolts.
Old 09-12-2011, 11:57 AM   #3 (permalink)
jakedog's Avatar
Member #2234
Thanks Helmet. Do I need to buy the special Honda Swingarm tool for this project?
Old 09-12-2011, 03:40 PM   #4 (permalink)
You can buy the tool or you can make one easy. Just get an impact socket that's the same diameter as the lock nut. Hold the socket up against the lock nut and mark the notches on the socket. Use a grinder to grind out the notches in the socket.
Old 09-12-2011, 10:30 PM   #5 (permalink)
Liked: 1388 times
this^^^^^ is a good idea, i just wanted to add..i've never messed with the outter lock nut..i always just loosened the allen nut bolt in the center..with a long cheater bar..and removed the whole thing out as one piece, main thing you need to watch when doing it this way..is try not to move the lock nut as your removing the center bolt..if you move it alot..then your center allen bolt wont be setting in the bearing the right debth.
2000 foreman swingarm bearings
2000 honda 450 foreman s swimgarm bushing
foreman loose swingarm
honda foreman 450 es rebuild swingarm
honda foreman 450 swingarm removal
honda foreman swingarm bearing replacement
honda foreman swingarm bearings
honda foreman swingarm removal
honda foreman swingarm repair
how to install swing arm bearings in honda 450 foreman
how to put swing arm bearings in foreman 450
rear swingarm bushing 2000 450 honda foreman
