08-10-2011, 12:56 AM
#1 (permalink)
Member #9976
Stuck in 2nd gear
Hey guys I got a problem that Ive been stumped on . The other day I went for a ride on my 2007 honda rancher 420 fe. It was doing great till I stopped and put it in reverse and backed up. I put it in 1st gear and went forward and when I shifted to 2nd gear the four wheeler would not move . I was unable to shift up or down unsure whats going on I think it might be the shift angle sensor. The gear position indicator gave me 2 long blinks and 2 short blinks
Any ideas would help the battery is fully charged the fourwheeler has 1200 miles on it. Thanks in advance ride safe.
08-10-2011, 01:09 AM
#2 (permalink)
I'd guess it's a shift position sensor,or maybe the angle sensor...Did you go download the free downloadable manual for your machine in the Schematics/Manuals section???...
08-10-2011, 08:17 AM
#3 (permalink)
Member #9976
To deeperinthabush, thanks for the reply I agree I think its the angle sensor. This web site is very helpfull,with good intel thanks again. Besafe.
08-10-2011, 12:51 PM
#4 (permalink)
Code 22 is shift angle sensor response. Could be a bad angle sensor or a bad shift motor. More than likely, a bad angle sensor.
08-11-2011, 12:37 AM
#5 (permalink)
Member #9976
Helmut , thanks for the advise. I havent priced them yet but what does an anle sensor run these days, thanks for for the a.dvise . Ride safe
08-11-2011, 12:44 AM
#6 (permalink)
You can usually find them for around $60. I would test the angle sensor before buying one. If you don't have a manual, you can download one from the manuals/schematics section of the forum and it will show you how to test the angle sensor.
08-11-2011, 12:47 AM
#7 (permalink)
No idea personally,but I bet it falls under the too much price range...
09-07-2011, 02:45 PM
#8 (permalink)
Member #9976
Hey guys thanks for the advise the problem was the shift angle sensor I checked the net the cheapest I found was at Discount OEM Polaris Parts, Polaris ATV Parts, Yamaha ATV Parts. 1-866-601-3827 for $42.00 it was part# 38800-hpo-a11. They said this fits all the ranchers. Besafe
09-07-2011, 03:15 PM
#9 (permalink)
Glad you got it fixed!!!
09-12-2011, 10:25 PM
#10 (permalink)
Member #9976
Just curious the gear position indicator stopped blinking . I havent erased the trouble code yet .But when I shift to 2nd gear I almost have to come to a slow speed but when I start moving again it shifts normal into 3,4,5 gear. Would the stored trouble code have a hand with this. I havent got the scs connector yet to erase the code 22 yet. Any thoughts would help
4 wheeler stuck in gear, atv stuck in 2nd gear, honda 4 wheeler stuck in gear blink, honda 4 wheelers stuck in second gear, honda 420 stuck in gear, honda atv stuck in 2nd gear, honda rancher 420 angle sensor, honda rancher 420 stuck in gear, honda rancher 420 stuck in second gear, honda rancher locked up stuck in gear, honda rancher stuck in second gear, rancher 420 stuck in gear
