Engine Stops when in put in gear - Honda ATV Forum
Old 08-06-2011, 03:14 PM   #1 (permalink)
sortdeuce39's Avatar
Member #12106
View sortdeuce39's Photo Gallery(0)
I have a 85 fourtrax. After I start the engine and put it in gear the engine stalls. any suggestions?
sortdeuce39 is offline   Reply With Quote
Old 08-06-2011, 03:35 PM   #2 (permalink)
Dan G's Avatar
Member #11269
View Dan G's Photo Gallery(0)
Liked: 6 times
Have you tried adjusting the clutches?
Old 08-06-2011, 09:41 PM   #3 (permalink)
Member #12106
does not have a clutch. only a shift lever left side foot.
Old 08-06-2011, 09:42 PM   #4 (permalink)
Member #12106
It ran when it was loaded into the pickup. got home started it and as soon as it was put into gear it stops.
Old 08-06-2011, 10:01 PM   #5 (permalink)
brent's Avatar
Member #8766
View brent's Photo Gallery(0)
posibly the one way bearing try to ask hlmnut
brent is offline   Reply With Quote
Old 08-06-2011, 10:12 PM   #6 (permalink)
Welcome to the forums. If the centrifugal clutch has been taken off and put back on recently, it could be the one-way bearing but if not, then I doubt it's the problem. It would have had to been taken off and the one-way bearing accidentally put back in backwards. Sometimes, a dirty carb can cause what you described. If you don't think it's the carb, it might be the CDI. I've seen some of the old '89-'89 Fourtrax/Foreman 350s do that and it was caused by a faulty CDI.
Old 08-07-2011, 10:23 AM   #7 (permalink)
Dan G's Avatar
Member #11269
Liked: 6 times
Right, it has a clutch, it just does it for you when you shift (no clutch lever). I was asking if you can adjust the clutches, most do but I've never worked on this model...
1986 yz 125 stalls when i put it in gear
atv engine stalls when put in gear
bayou 220 rolls when put in gear
bayou 220 stalls when put in gear
bayou 220 stalls while putting in gear
bayou 300 centrifugal clutch
engine stalls when you put it in gear on a kawasaki h1 500
engine stops when put in gear
honda stall when i put it in gear
kawasaki bayou 220 stalls when put in gear
kawasaki prarie 220 stalls when i put in gear
www.rebilding engen.com
