another 300ex problem - Honda ATV Forum
Old 07-11-2011, 05:50 PM   #1 (permalink)
99trx400ex's Avatar
Member #3449
View 99trx400ex's Photo Gallery(0)
Question another 300ex problem
my 300ex is running very bad lately. once you get it running ever now and then (about 10 times in about an hour) it will bog down and try to die and you have to pull the clutch and give it full throttle and it will sometimes rev back up and not die but sometimes it still dies anyway. you have to stay on the clutch and rev it up all the time to make sure it stays running. the only time this isnt a problem is if you keep it at high rpm in all gears. if you are moving pretty fast and pull the clutch in and apply the brakes to slow down for a turn or something once again you have to rev it the whole time or it will die. also if you are in first or second gear and pop the clutch to pop up it dies everytime you get the front wheels of the ground. so basically it runs good at high rpm but wants to die and bog down if you are at a low rpm or if you arent always giving it trottle and also its a 1994 so im sure there are possibly a number of parts that could be wore out.....hope you guys can help, thanks
trx400ex:
-hmf slip-on
-k&n air filter
-pro armor nerf bars
-pro taper handlebars
-dg bumper
foreman 500es:
-k&n air filter
trx300ex:
-k&n air filter
99trx400ex is offline   Reply With Quote
Old 07-11-2011, 05:56 PM   #2 (permalink)
Liked: 52 times
Have you replaced the spark plug with a new correct part numbered one lately?? It could be running too rich,or have a sticking float problem,,,
Old 07-11-2011, 06:12 PM   #3 (permalink)
99trx400ex's Avatar
Member #3449
i took the spark plug out to change it and it was matte black. im guessing its running rich or maybe oil fouled.....idk. im going to change it this weekend but if its running rich couldnt this just happen again. since its a 94 im thinking about getting a full carb rebuild kit and maybe that could help. also the choke barely seems to make a difference on how it runs no matter what position its in
trx400ex:
-hmf slip-on
-k&n air filter
-dg bumper
foreman 500es:
-k&n air filter
trx300ex:
-k&n air filter
Old 07-11-2011, 06:21 PM   #4 (permalink)
99trx400ex's Avatar
Member #3449
also the black wire that goes into the red boot that goes on top of the spark plug came out when i removed the plug. do i need a new plug wire or can this one be fixed and if i need a new one where can i get one and are the expensive?
trx400ex:
-hmf slip-on
-k&n air filter
-dg bumper
foreman 500es:
-k&n air filter
trx300ex:
-k&n air filter
Old 07-11-2011, 06:21 PM   #5 (permalink)
Member #417
Liked: 286 times
Sounds like the idle circuit is clogged. Idle circuit being air/fuel screw, and slow jet
As far as the wire take a pair of side cutters and clip off about 1/2" the boot has a screw in it stck the wire in as far as you can and twist the boot on until it feels snug. That's probably the whole issue.
Old 01-15-2015, 04:59 PM   #6 (permalink)
300ex19's Avatar
Member #44200
View 300ex19's Photo Gallery(0)
Mine is doing the same thing could the pilot jet need to be cleaned?
300ex19 is offline   Reply With Quote
300ex black plug
300ex bogs at high rpm
300ex missing at high rpms
300ex popping
300ex popping at high rpm
300ex spark plug black
300ex spark plug is black
300ex spark plug number
94 300ex spark plug wire
bogging at high rpm on 300ex
trx300ex splatters at high rpm?
what number spark plug go in honda 300
