Old 06-20-2011, 11:28 AM   #1 (permalink)
badtyler90's Avatar
Member #11135
View badtyler90's Photo Gallery(0)
1986 honda trx200sx wiring problem
howdy im new here but not to vehicles atv yes i bought a 1986 trx200sx yesterday for 75 bucks motor has great compression everything looks good only bad thing was it needed total rewire as someone decidedx to yank apart all the wires so i downloaded a 200sx wiring diagram and had all wires right when to start with pull start i am not running electric starter as now battery mount was available and dont want to mess with wiring that in i didnt hook up the statrter button or headlight tail lights no there but there is no spark so i got my ohm meter out checked coil coil was goo on the plug wires end but cant seem to get a reading from the spark plug end but plug is good as i can get reading from both ends of plug with ohm meter so it's getting current threw but i went to test cdi box not getting any ohms threw it so i trash the cdi box and now trying to hot wire it where the cdi box used to be any help would be aprriciated or a internal diagram of the cdi box would help also and i yanked carb took it apart nd soaked it in gas over night and brush cleaned the insde this morning and got all the gunk out i am wanting to by pass the key bypass the starter voltage regulator and bypass the cdi box all i want that gets power is the coil and plug and the kill switch if possible if not i can kill it by the choke mainly i want this thing to fire and run without alot of wires running for stuff i don't need i'm used to pull start so electric start i don't need. thanks T-Rob
badtyler90 is offline   Reply With Quote
Old 06-20-2011, 01:08 PM   #2 (permalink)
Member #417
Welcome to the forums.
You cannot omit the CDI or regulator. check your reverse wiring. Bypass it and look for spark. take the coil wire boot and unscrew it off of the wire take a pair of side cutters and cut about 1/2" off and screw the boot back on. check for spark then.
1991 TRX 250X
400EX carb, UNI filter,
Secret engine ingredients
FMF Power Core 4 full exhaust,
400EX front suspension
450R front shocks,LT250R rear shock
Custom oil cooler
check it out
http://www.hondaatvforums.net/forums...-makeover.html
Old 06-20-2011, 01:15 PM   #3 (permalink)
Welcome to the forums. Like Moose said, there's no way that you can bypass the CDI and regulator. You have to have both for the ATV to run.
Old 06-22-2012, 04:09 PM   #4 (permalink)
bbron12's Avatar
Member #20091
View bbron12's Photo Gallery(0)
hi, im having a similar issue on my '86 200sx. If i turn the key on, i can turn the lights on, hi and low, but thats it. no dash indicator lights, no starter, no spark if i pull it over, nothing. the main fuse is good and all the wires are in good shape and plugged in properly. what should i do and what can it be?
bbron12 is offline   Reply With Quote
Old 06-22-2012, 10:00 PM   #5 (permalink)
Welcome to the forums. You could have a bad neutral switch. I would unplug the green/red wire that goes to the neutral switch and temporarily ground it to the engine and see if the neutral light comes on and if the quad will start, then. If so, the neutral switch is bad.
Old 06-23-2012, 08:57 AM   #6 (permalink)
bbron12's Avatar
Member #20091
ok, do i ground both of the wires? and also, will that make the reverse light work too?
Old 06-23-2012, 09:12 AM   #7 (permalink)
bbron12's Avatar
Member #20091
also, i just realized, the little neutral indicator knob thing behind the shifter doesnt move, no matter what gear its in, n=but i dont beleive that has any mechanical influence, just the switch. how do i go about wiring it so its always in neutral so it will always run? my key switch is good for sure. also, is it the 2 wires coming out of the transmission kind of above the front sproket?
Old 06-23-2012, 09:49 AM   #8 (permalink)
bbron12's Avatar
Member #20091
i got that light green one grounded, and yep, that was the trick! the light came on and it turns over now, but im not getting any spark now. I have a brand new plug on it, and i cut about 1/4 inch or so of old wire off the plug boot, then put the boot back in tightly, and still no spark. any thoughts on that? thanks again!
Old 06-23-2012, 10:32 PM   #9 (permalink)
You didn't ground the reverse wire, too, did you? If you did, that will keep it from starting/firing since the CDI won't allow the quad to start in reverse.
How did this problem come about? Did the problem start all at once? Were you getting spark by pulling the recoil starter, before grounding the neutral wire? Has the quad been sitting for any length of time?
Old 08-11-2012, 12:17 PM   #10 (permalink)
KAGEBELLUCCI's Avatar
Member #21981
View KAGEBELLUCCI's Photo Gallery(0)
sounds like im in the wrong place but i need a lil help with some basic info on my honda 1986 trx200sx!!!! first what kind of oil should i run in it? also what kind of tranny fluid should i run in it anything helps thanks
KAGEBELLUCCI is offline   Reply With Quote
1986 atv trx honda sx how to test stater trouble shoot
1986 honda fourtrax 200 used cdi
1986 honda trx200sx wiring diagram
1986 trx honda sx 200 atv find electrical schematics
86 tecate wire diagram to bypass switch
can i turn on my four wheeler honda 200 with no cdi box
cdi box honda 200 sx
gear position switch on a 1986 honda fourtrax 200sx
honda fourtrax 200 1986 wiring diagram
honda trx 200 wiring diagram download
how many wires is hot coming out of cdi box on four wheeler
is there a way to bybass the cdi boxxx
