oil in airbox? - Honda ATV Forum
Old 06-14-2011, 02:27 PM   #1 (permalink)
2000honda300ex's Avatar
Member #8799
View 2000honda300ex's Photo Gallery(0)
oil in airbox?
I have my 2000 300ex with hmf slip-on, 130# jet, Big Gun rev box, uni air filter and the rest is stock. Well when I was washing her down I noticed in the airbox drain tube on the bottom it was filled over half way with oil. I always keep her clean but dont clean that part as often. I emptyed the drain tube and cleaned really good and did 15min. worth of riding and had more oil in drain tube (not alot but enough to cover bottom). The airbox itself was clean inside, the air filter is new. Could this be from excessive air filter oil? But the air filter didnt look overloaded with oil to me. Any thoughts or help?
2000honda300ex is offline   Reply With Quote
Old 06-14-2011, 02:33 PM   #2 (permalink)
rwbagnato's Avatar
Member #10877
View rwbagnato's Photo Gallery(0)
Might be slight blow-by out the crankcase breather. To check this pull the crankcase breather off the bottom of the airbox and see if its blowing oil out there. Might have to put the motor under a load such as power braking it. Also check the oil level, if its over filled it will do the same thing.
rwbagnato is offline   Reply With Quote
Old 06-14-2011, 09:12 PM   #3 (permalink)
Liked: 53 times
Yep,what RW said...Also,make certain that you're using the called for oil weight in your motor...
Old 06-14-2011, 09:18 PM   #4 (permalink)
Banned
elmerkit's Avatar
Member #2486
View elmerkit's Photo Gallery(0)
Is your oil in the right level? may be the pcv valve is clog.
elmerkit is offline   Reply With Quote
Old 06-14-2011, 10:25 PM   #5 (permalink)
bobs330's Avatar
Member #8144
you could do a leakdown test--hook an air compressor to your spark plug hole (you need the fitting) andpressurize the cylinder, this will also tell you if you have leaky valves too. if oils blowing in the tube, you got worn rings/cylinder
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
2000 rancher oil in airbox
300ex oil breather
300ex oil in air filter
300ex oil in airbox
honda 300ex oil in airbox
honda atv pcv valve
honda atv pvc valve
honda rancher airbox full of oil
honda rancher oil in airbox
oil in air box atv
oil in the airbox
pvc valve on honda rancher
