air cut off valve - Honda ATV Forum
Old 06-10-2011, 06:21 PM   #1 (permalink)
brent's Avatar
Member #8766
View brent's Photo Gallery(0)
air cut off valve
i am cleaning my carb and how do i check the cut off valve to make sure it is ok i had someone suck on one end to create a vacume and i blew on the other end and air went through it is that how you check it
brent is offline   Reply With Quote
Old 06-10-2011, 06:34 PM   #2 (permalink)
While pulling a vacuum on the hose on the valve, you shouldn't be able to blow through the other two ports, but you should be able to blow through the ports when no vacuum is being applied.
Old 06-10-2011, 06:38 PM   #3 (permalink)
brent's Avatar
Member #8766
ok
ya when we are sucking on one end and blowing on the the other air is going through it
Old 06-10-2011, 06:42 PM   #4 (permalink)
Air shouldn't be going through the ports while you're pulling a vacuum, but maybe you aren't pulling a strong enough vacuum. I believe it takes a vacuum of about 18 in of Hg. to close the valve.
Old 06-10-2011, 07:21 PM   #5 (permalink)
brent's Avatar
Member #8766
ya well i am sucking as hard as i can and we can blow through it so it looks like i am buying a 70.00 part
Old 06-10-2011, 07:25 PM   #6 (permalink)
I don't think the valve being bad will keep it from running or anything. The purpose of the air cut off valve is to keep the engine from popping or backfiring on quick deceleration. I would check Ebay or somewhere and try to find a used one cheaper.
air cut of valve honda problems
air cut off valve atv
air cut valve assembly
air cutoff valve
bad air cutoff valve
cm450 air cut valve purpose
honda air cut off valve
honda air cut valve
honda air cutoff valve
honda phantom air cut-off valve
how to test air cut off valve
valve assy., air cut
